New to PlusNet Fibre Broadband
Rogerwaters
When you first join Plusnet is the speed reduced as on BT I was in 60-70 download speed and now nearer 50
1 REPLY
Aspiring Hero
Fixes: 70
Re: New to PlusNet Fibre Broadband
It can do. What happens is the DLM in the BT cabinet automatically ‘tunes’ your line to the maximum speed over time. If you change ISP Openreach reset the DLM so that it has to start this tuning all over again. If you’re patient it should get back to where it was. The time it takes seems to be a bit hit and miss.
