New to PN from BT - Low speed, but only on one device.
FIXED- Subscribe to RSS Feed
- Re: New to PN from BT - Low speed, but only on one...
11-07-2017 12:27 PM
I set my PN Hub up yesterday, but the PC I originally connected with will only reach a speed of 1mbs at best. No settings were changed and all I had to do was disconnect my BT homehub 5 and plug the Plusnet one in. Other devices connected are PS4 through wireless, which tests at about 12-16mbs and a laptop which connected effortlessly wireless and also have tried wired on laptop, both give me top speeds of 17.mbs.
For some unknown reason, the desktop pc upstairs is incredibly slow. It was okay the night before on BT and no other settings have been changed. Connecting to the hub settings tells me that the downstream is 18mbs, but speedtest is having trouble hitting 1,0mbs.
The only difference I can think of between the devices is that the PC is using a USB net adapter. PS4, laptop, both phones all connect at top speed.
Im usually pretty good with things like this, but this has really got me stumped!
Any suggestions? I'm very happy with my new service, apart from on the main PC
Fixed! Go to the fix.
Re: New to PN from BT - Low speed, but only on one device.
11-07-2017 12:32 PM
How about the obvious
Either the USB wireless adapter is having problems - what is the signal strength
Or it has connected to another BT Router where the wireless isn't secured
11-07-2017 12:44 PM
Have tried 2 different adapters, both dual band. I've tried separating the channels into 5 and 2.4 ghz, same on both. Signal is good and I'm defnately connected to plusnet router
11-07-2017 12:49 PM
That scuppers my suggestions
How about this one - guess who is clutching at straws - try disabling the internet security package on the computer
11-07-2017 12:55 PM
Tried that first :D, disabled then uninstalled. No firewall or AV running. I had Windscribe VPN installed but turned off, uninstalled that too. I'm truely at a loss.
11-07-2017 1:40 PM
Have you tried using the BT HH5? You will need to enter your PN username and password.
11-07-2017 2:15 PM
Help chat suggested that too but for some unknown reason the page keeps refreshing before I get chance to enter my username and password. Back on PN hub again now, still the same, dead slow on pc, fine on everything else. Tried using chrome and IE. Grrrrr.
Open to suggestions
11-07-2017 3:17 PM
That could be because the Hub may be locked to BT.
Open to suggestions
Another shot in the dark... have you tried a factory reset of the router? Also, if at all possible, connecting your PC to the router via ethernet to narrow down where the issue could lie?
11-07-2017 3:39 PM
Yes, also tried that Gandalf but thanks anyway
I seem to have solved it. I re-installed Windscribe, switched it on and everything runs normally again!
I think Windscribe has its own firewall which hung around after uninstalling causing problems.
At least I can connect now and work out how to fully un-install the damn thing.
Thank you all for your help
11-07-2017 3:44 PM
Just seen this.
I, too, have Windscribe installed. I installed the FF addon and noticed that occasionally just FF slows down to a crawl. Up to now my remedy has been to quite FF and start it again and all seems OK for some time.
I will disable Windscribe a while to see if it sill happens.
Forum Moderator and Customer
11-07-2017 8:04 PM
Sorry for the late reply.
@Gandalf many people use the BT HH5 on PN, all you need is your PN username and password.
@BusStopWilly Entering your details can be tricky, but if you press the disconnect icon before you do so, then connect after you should find it easier.
HTH
