New to Fibre
zephyr4
New to Fibre
I have just moved from adsl to fibre I started to get some faults between me and a mate in Ireland when using skype I did a speed test and my download was just over 3meg on adsl I got 12 meg at night and 17-18 meg in the day, all was ok till 7pm and bang down to 6 meg this has happened the last few days.
Forgot to mention I live about 75 yards from my exchange.
Thanks for any help steve
8 REPLIES 8
Fixes: 1,600
Re: New to Fibre
Sorry to hear you're having speed issues.
It looks like your service is running on a hot virtual path.
This essentially means that the equipment at the exchange is overutilised. It's due to be fixed on the 10th November, however, I've contacted our suppliers to see if we can move your service to a cooler VP.
Can you let us know how it goes over the next few days?
Apologies for any inconvenience caused.
Anoush
zephyr4
Re: New to Fibre
Went down to  3 meg last night for a while, when you say over overutilised do you mean the whole exchange.
I only live about 50-60 yards from the exchange and had to wait longer to get fibre because I was wired direct to the exchange so I had to wait till they installed a cabinet outside the exchange.
Fixes: 1,600
Re: New to Fibre
No, just the SVLAN your circuit is connected to.
We're hoping that when you're moved to a different SVLAN that should resolve the problem.
zephyr4
Re: New to Fibre
Thanks for the update.
I don't know a lot about it I usually ring my nephew who some times works at my local exchange but he's on holiday in Croatia.
Fixes: 1,600
Re: New to Fibre
It appears that your circuit has been moved to a cooler/less utilised SVLAN.
How's your speed looking?
zephyr4
Re: New to Fibre
Just ran a test 6.35pm(see attachment)  and its ok will try again in a while.
zephyr4
Re: New to Fibre
I would like to say thanks to Gandalf and the Plusnet team for sorting out my problem, first class service.
z4
MatthewWheeler
Fixes: 479
Re: New to Fibre
Glad to hear it's sorted!
 Matthew Wheeler
