New to FTTC today but well below expected clean
- New to FTTC today but well below expected clean
23-04-2018 6:55 PM
Getting 18 instead of 40, which is quite disappointing for a change from a very good ADSL connection . I have a Mk 5 SSFP employed too.
I hope I shall see an improvement, but, please, will someone look to see if there is a problem?
Re: New to FTTC today but well below expected clean
24-04-2018 11:49 AM
Have you any thoughts on this?
24-04-2018 12:04 PM
Call customer service and report a speed fault and don't accept any nonsense about there being a 10 day training period for FTTC, it isn't true.
24-04-2018 12:25 PM
@Gandalf - can you please confirm this assertion?
Thereafter it’s a line fault ... and there is no 10 day stabilisation period for fibre ... so do push back on any wait 10 day answer.
24-04-2018 12:31 PM
Sorry to hear you're experiencing speed problems with your new fibre service.
My first instinct is that having moved from a “very good” ADSL service (18+ Mbps?) your PN profile has not yet updated to the FTTC capability ... which (I believe to still be the case) if you have a fixed IP address still influences download speed.
The speed profile on your account is still set to 6300kbps. As you're getting 18mbps that's not having an impact.
Our tests are showing your router in sync at 17.9mbps with no obvious causes.
Assuming you've tried the checks here I'd raise a fault to us a http://faults.plus.net so we can arrange an engineer.
24-04-2018 2:17 PM
@Townman ADSL speed was 6-7000 kbps
@Gandalf I don't get comment, The speed profile on your account is still set to 6300kbps". Even if it makes no difference, how can an ADSL profile be on a VDSL connection.
I will do tests idc.
24-04-2018 2:34 PM
Apologies for the confusion. I was referring to the speed profile on your account on our side. This should automatically match the IP profile of the line but can take a few days to adjust by itself.
Due to the way your connection routes across our network this won't be having an impact on your speeds.
24-04-2018 3:02 PM
Gandalf has affirmed that in your case it has no bearing.
24-04-2018 6:38 PM
@Gandalf I attempted to use the test socket of my own router, but could not get on line, but the computer network settings evidenced activity @ 72 Mbps.
If I may, I'll take the offer PN's router for P&P costs. That'll teach me to not be stingy!
Can one be sent asap? Please!
24-04-2018 7:26 PM
When you plugged your router into the test socket, was the DSL light stable or flashing?
I’ll be happy to send you a Hub One router though, this will be tomorrow’s task when I’m back in the office.
24-04-2018 8:56 PM
@GandalfThank you for reply. I shall await the router. I wasn't meaning speed obtained, more of evidence something going on.
TBH after so many hours I don't recall sate of DSL light, I do recall the WAN light being illuminated, but dull. RJ11 in test socket was difficult to choose whether should be inserted clip up or down.
25-04-2018 12:43 AM
This thread is severely lacking info!
What are the expected speeds which can be found here?
and
What does the router indicate in it's stats page?
25-04-2018 12:43 PM
@Luzern no problems, I've sent you a new router now. It should arrive shortly.
A RJ11 connector wouldn't fit into the test socket. You'll need to use a microfilter.
The new router we'll send you will come with one if you don't have a filter.
25-04-2018 5:46 PM
@Gandalf It came to me earlier today. Dare I put it down to a severe senior moment hour? My Billion 8800NL is in the test socket, but there appears to be no improvement.
For record
Connection statslate 23/4
adsl info --stats adsl: ADSL driver and PHY status Status: Showtime Last Retrain Reason: 8000 Last initialization procedure status: 0 Max: Upstream rate = 5642 Kbps, Downstream rate = 20935 Kbps Bearer: 0, Upstream rate = 5642 Kbps, Downstream rate = 18158 Kbps Link Power State: L0 Mode: VDSL2 Annex B VDSL2 Profile: Profile 17a TPS-TC: PTM Mode(0x0) Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 5.9 6.4 Attn(dB): 26.4 0.0 Pwr(dBm): 11.8 6.3 VDSL2 framing Bearer 0 MSGc: 26 26 B: 51 175 M: 1 1 T: 57 38 R: 12 14 S: 0.0910 0.9896 L: 5624 1536 D: 355 1 I: 64 95 N: 64 190 Counters Bearer 0 OHF: 4337108 619232 OHFErr: 21 5 RS: 988817370 1142886 RSCorr: 22359 7 RSUnCorr: 1839 0 Bearer 0 HEC: 365 0 OCD: 2 0 LCD: 2 0 Total Cells: 788952631 0 Data Cells: 3820693 0 Drop Cells: 0 Bit Errors: 0 0 ES: 36 8 SES: 20 0 UAS: 10825 10805 AS: 22581 Bearer 0 INP: 3.00 0.00 INPRein: 0.00 0.00 delay: 8 0 PER: 5.20 9.43 OR: 49.14 27.12 AgR: 18206.87 5669.13 Bitswap: 601/601 625/625 Total time = 9 hours 26 min 8 sec FEC: 22359 7 CRC: 21 5 ES: 36 8 SES: 20 0 UAS: 10825 10805 LOS: 2 0 LOF: 16 0 LOM: 0 0 Latest 15 minutes time = 11 min 8 sec FEC: 19 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 15 minutes time = 15 min 0 sec FEC: 366 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 1 day time = 9 hours 26 min 8 sec FEC: 22359 7 CRC: 21 5 ES: 36 8 SES: 20 0 UAS: 10825 10805 LOS: 2 0 LOF: 16 0 LOM: 0 0 Previous 1 day time = 0 sec FEC: 0 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Since Link time = 6 hours 16 min 37 sec FEC: 22359 7 CRC: 21 5 ES: 8 5 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 >
This morning G_INP had been enabled. Her are details of that and new connection stats taken this morning.
Downstream Upstream General rtx_tx 39 0 rtx_c 39 0 rtx_uc 0 0 LEFTRS 1 0 minEFTR 20733 0 errFreeBits 6330422 0 Bearer 0 RxQueue 16 0 TxQueue 8 0 G.INP Framing 18 0 G.INP Lookback 8 0 RRC Bits 0 24 Interleave depth 8 1 INP 43.00 0.00 INPRein 0.00 0.00 Delay 0 0 Bearer 1 Interleave depth 1 0 INP 2.50 0.00 INPRein 2.50 0.00 Delay 0 0 ============================================================== adsl info --stats adsl: ADSL driver and PHY status Status: Showtime Last Retrain Reason: 1 Last initialization procedure status: 0 Max: Upstream rate = 5594 Kbps, Downstream rate = 21183 Kbps Bearer: 0, Upstream rate = 5594 Kbps, Downstream rate = 20737 Kbps Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps Link Power State: L0 Mode: VDSL2 Annex B VDSL2 Profile: Profile 17a TPS-TC: PTM Mode(0x0) Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 6.4 6.3 Attn(dB): 26.4 0.0 Pwr(dBm): 11.8 6.3 VDSL2 framing Bearer 0 MSGc: -6 26 B: 235 175 M: 1 1 T: 0 38 R: 14 14 S: 0.3622 0.9980 L: 5522 1523 D: 8 1 I: 250 95 N: 250 190 Q: 8 0 V: 1 0 RxQueue: 16 0 TxQueue: 8 0 G.INP Framing: 18 0 G.INP lookback: 8 0 RRC bits: 0 24 Bearer 1 MSGc: 90 -6 B: 0 0 M: 2 0 T: 2 0 R: 16 0 S: 10.6667 0.0000 L: 24 0 D: 1 0 I: 32 0 N: 32 0 Q: 0 0 V: 0 0 RxQueue: 0 0 TxQueue: 0 0 G.INP Framing: 0 0 G.INP lookback: 0 0 RRC bits: 0 0 Counters Bearer 0 OHF: 0 362628 OHFErr: 0 1 RS: 222352760 3692510 RSCorr: 463 2 RSUnCorr: 0 0 Bearer 1 OHF: 1258396 0 OHFErr: 0 0 RS: 7550008 0 RSCorr: 6 0 RSUnCorr: 0 0 Retransmit Counters rtx_tx: 45 0 rtx_c: 45 0 rtx_uc: 0 0 G.INP Counters LEFTRS: 1 0 minEFTR: 20733 0 errFreeBits: 6387300 0 Bearer 0 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 806067206 0 Data Cells: 5836847 0 Drop Cells: 0 Bit Errors: 0 0 Bearer 1 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 0 0 Data Cells: 0 0 Drop Cells: 0 Bit Errors: 0 0 ES: 13 6 SES: 10 0 UAS: 3428 3418 AS: 20216 Bearer 0 INP: 43.00 0.00 INPRein: 0.00 0.00 delay: 0 0 PER: 0.00 9.51 OR: 0.01 26.89 AgR: 20769.93 5621.15 Bearer 1 INP: 2.50 0.00 INPRein: 2.50 0.00 delay: 0 0 PER: 16.06 0.01 OR: 47.81 0.01 AgR: 47.81 0.01 Bitswap: 418/418 530/530 Total time = 16 hours 56 min 33 sec FEC: 61869 15 CRC: 1790 7 ES: 13 6 SES: 10 0 UAS: 3428 3418 LOS: 1 0 LOF: 7 0 LOM: 0 0 Latest 15 minutes time = 11 min 33 sec FEC: 68 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 15 minutes time = 15 min 0 sec FEC: 9 0 CRC: 0 1 ES: 0 1 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 1 day time = 16 hours 56 min 33 sec FEC: 61869 15 CRC: 1790 7 ES: 13 6 SES: 10 0 UAS: 3428 3418 LOS: 1 0 LOF: 7 0 LOM: 0 0 Previous 1 day time = 0 sec FEC: 0 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Since Link time = 5 hours 36 min 55 sec FEC: 463 2 CRC: 0 1 ES: 0 1 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 >
When the router arrives, I use it, as I guess I'll need do that for the faulting purpose.
@Browni I hope the above is also useful to you,
Plusnet wae 36/24
OT Noted that against my ADSL estimates is "Left in Jumper", but at my daughter's, who has been on fibre for a few years, nothing. Significance, if any?
29-04-2018 5:20 PM
@Gandalf and other staff. The performance of my Fibre gives little hope that sync will increase much beyond the MIGALS. I can see no effective way of contacting HQ. Therefore this is formal notice to Plusnet, given at 17:14 hours 29/04/2018 that I invoke my right reject the current VDSL service on my account, and wish to revert to my previous legacy ADSL 2+ service at the same monthly cost and benefits as before.
