New speed problem
medea
New speed problem
Long term 40/20 user with static IP address.  Enforced switch to 55/10 eventually settled down with very steady speeds of 51~52 / 9.4-9.5 and very stable pings 16-20ms.  Recently pings have become more variable and now performance has fallen off with download speed under 38, upload unchanged.  iplayer has shown a tendency to hang which is a nuisance that used to be very rare.  Attached ping graph seems fairly typical
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/a5b6449ecf78946240076118edbb5f5f-25-10-2016.html"><img alt="My Broadband Ping - RogerFibre" src="http://www.thinkbroadband.com/ping/share-thumb/a5b6449ecf78946240076118edbb5f5f-25-10-2016.png" /></a>
Suggestions please.
5 REPLIES 5
Andrue
Re: New speed problem
All looks fairly normal to me. Just a connection in use during the day and mostly idle at night. There's a small amount of packet loss around 2am but barely worth mentioning.
jelv
Fixes: 10
Have you checked your IP Profile from a BT diagnostic speed test and the current line speed?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Chris
Legend
Fixes: 169
Testing your line isn't showing any problems. There was an incorrect setting on your account that I've now corrected, can you try a disconnect/reconnect of the router and see if the speeds improve?
medea
Thanks Chris.  Normal service resumed.  Confirmed with BT speed test.
Prompt service much appreciated.
Mav
Fixes: 513
Moderator's note by Mike (Mav): I have changed the fix to Chris as per message 5.
Forum Moderator and Customer
