New setup, only connects as ‘setup@plusdsl.net’
FIXED- Subscribe to RSS Feed
- Re: New setup, only connects as ‘setup@plusdsl.net...
16-09-2020 11:19 PM
Fixed! Go to the fix.
17-09-2020 9:04 AM
Try another factory reset. Your account wasn't fully activated at our side. I'm hoping it should be OK now?
Re: New setup, only connects as ‘setup@plusdsl.net’
17-09-2020 9:13 AM
Not quite sure whether a reset would do the trick you have to go into A-Z on the router and find change user name, input your username and password and try that.
I noticed a similar proble last evening, my router started to drop out at around 19.30 and did so on a regular basis sometime lasting only 4 mins. I then noticed the router had defaulted to setup@plusdsl.net eventually got it reverted to *******@f9.co.uk got connected but did not go stable till around 06.30 this morning. I did also notice that during this time the phone line was noisey and that has cleared this morning. I have also noticed my ip profile has dropped from 76Mbps to 50Mbps but trust this will go back up as long as the line stays stable. I am sure help is around but would like to know if there was a problem starting around 19.00hrs on the 16th overnight and if so what was it. perhaps @bobpullen or @Gandalf may advise and also check your problem.
17-09-2020 9:27 AM
A reset should work perfectly fine and is the preferred approach. Manually configuring the device is not desired as it can lead to the device not being registered correctly on the hardware management platform. Something that may prevent you receiving updates further down the line.
I doubt the issue you experienced is related and I'm not aware of any widespread problems.
17-09-2020 9:50 AM
Yep, that did the trick, all sorted now. Thanks.
