New router to improve wi-fi
- New router to improve wi-fi
06-05-2015 3:24 PM
I've had Plusnet fibre for a couple of years now and have finally lost patience with the poor wi-fi performance of the old Technicolor 582n, so I'd like to replace it with something a bit stronger.
Can any of you good people recommend a decent replacement that is easy to set up and won't cost the earth? (I'm on a pretty limited budget of £40 max).
Message 1 of 9
(1,146 Views)
8 REPLIES 8
Re: New router to improve wi-fi
06-05-2015 3:38 PM
Have a mooch here.... http://forum.kitz.co.uk/index.php/topic,14436.0.html
Emphasis on G.INP
Emphasis on G.INP
Message 2 of 9
(681 Views)
06-05-2015 3:44 PM
Thanks for the reply - although I'm quite happy with the BT Openreach modem, I'm just looking for a budget router that's better than the Technicolour
Message 3 of 9
(681 Views)
06-05-2015 3:49 PM
I use 2x D-Link Dir-615 routers for WiFi access points in my home with DD-WRT firmware
They give very powerfull options running DD-WRT as an AP many other routers can be used as well, have a look at the database above.
That should cost you no more than £15 for 2!
Message 4 of 9
(681 Views)
06-05-2015 3:50 PM
This appears to be a bargain and just in your specified price range. No idea how good it really is or the seller though
Call me 'w23'
Message 5 of 9
(681 Views)
06-05-2015 3:53 PM
I have one of these, dual band wireless, Gigabit Ethernet ports.
Pretty good in my opinion.
http://www.tp-link.com/en/products/details/cat-9_TL-WDR3600.html
There are a few on eBay.
http://www.ebay.co.uk/sch/i.html?_from=R40&_sacat=0&_nkw=tl-wdr3600&rt=nc&LH_PrefLoc=1
Message 6 of 9
(681 Views)
06-05-2015 3:57 PM
I use a D-Link DIR-655, it has a gigabit ethernet WAN port and I have used it successfully to max out my parents' Virgin connection which is 165Mbps so it is more than good enough for current and probable future FTTC offerings.
It has just been discontinued but is still being offered on Amazon for £60. Second hand units will presumably be cheaper still. Bargain.
[edited to add - the wireless is however only 2.4GHz]
Message 7 of 9
(681 Views)
06-05-2015 4:33 PM
Really impressed at all the helpful responses - thanks all!
I think I might go for the D-Link http://www.ebay.co.uk/itm/D-link-DIR-655-300-Mbps-4-Port-Gigabit-Wireless-N-Router-/151663210186?pt=... or the TP-Link http://www.ebay.co.uk/itm/TP-LINK-TL-WDR3600-N600-Dual-Band-Wireless-Cable-Router-Black-Open-Box-/11....
Is it just a case of disconnecting the old Technicolour and plugging the new router into the Openreach modem? Apologies if it's a dumb question, I consider myself fairly computer-literate but anything to do with internet setup or networking makes my head spin!
Message 8 of 9
(681 Views)
06-05-2015 4:37 PM
You'd need to enter your user login details (usually in the form of usename@plusdsl.net) and password in the appropriate place (after ensuring the router is set for PPPoE connection).
I think most routers make this a simple procedure. Login details can be found at: https://portal.plus.net/my.html?s=0&action=refresh_browser (login required!)
Call me 'w23'
Message 9 of 9
(681 Views)
