New router for new Fibre install
dokez777
Is this router going to be ok for the job
http://www.pcworld.co.uk/gbuk/networking/networking/cable-wireless-routers/tp-link-tl-wdr3600-n600-d...
TP LINK WDR3600 CABLE model
Or do I need the modem model ?
carlmagic
Re: New router for new Fibre install
Should be fine, the blue port on the back is the WAN port connect that to the BT Openreach modem that you get installed when the engineer comes out
I've been using that model just fine for a while now, running the standard TP-Link firmware. It works well at both 2.4GHz and 5GHz.
Right now, I have flashed it with a version of OpenWRT firmware, so I can connect a 4G modem to it.
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
dokez777
Thanks Carl, and nice to know Wombat  Cheesy
