New router for new Fibre install
- Re: New router for new Fibre install
09-11-2014 6:24 PM
Is this router going to be ok for the job
http://www.pcworld.co.uk/gbuk/networking/networking/cable-wireless-routers/tp-link-tl-wdr3600-n600-d...
TP LINK WDR3600 CABLE model
Or do I need the modem model ?
Message 1 of 4
(1,010 Views)
3 REPLIES 3
09-11-2014 8:26 PM
Should be fine, the blue port on the back is the WAN port connect that to the BT Openreach modem that you get installed when the engineer comes out
Message 2 of 4
(453 Views)
10-11-2014 12:43 AM
I've been using that model just fine for a while now, running the standard TP-Link firmware. It works well at both 2.4GHz and 5GHz.
Right now, I have flashed it with a version of OpenWRT firmware, so I can connect a 4G modem to it.
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Message 3 of 4
(453 Views)
10-11-2014 9:32 PM
Thanks Carl, and nice to know Wombat
Message 4 of 4
(453 Views)
