New router but no code. Plusnet not accepting calls
- Re: New router but no code. Plusnet not accepting ...
10-10-2020 7:50 AM
Any thoughts out there please? Thanks
Re: New router but no code. Plusnet not accepting calls
10-10-2020 8:20 AM
@sheppwestilsley What code are you expecting? If you are using a Plusnet router it should automatically pick up your username and password directly when it is connected. Assumng that your phone line works and the Broadband has been activated. Have you had any communication from Plusnet about when it should go live? Try looking in your member centre account for any service notices or questions. They may indicate if the service is ready to use, or just try plugging the router in and see what happens.🙂
10-10-2020 8:24 AM
10-10-2020 9:32 AM - edited 10-10-2020 9:33 AM
Are there any questions at the bottom of this page on your account?
You will need to login when prompted.
The question history may show a different date for the installation if Openreach could not meet the inital date.
Plusnet are poor at communicating the Openreach confirmed date for an installation.
Regards
Richard
