New install
taras
New install
just had the OR guy over, gave me the eci modem (yuck!).
Anyways my tn582n decided to play up and ask for the password every time i pressed ok .(5.2 fe firmware). and despite putting my username in (krusty) it decided the tr69 name was more suitable (sorry pn tech support).
I sorted that issue out but my download speeds are set at 3.8mbits (ip profiles?)
The OR guy said its syncing at 9.1mbits and bt dsl checker quoted
FTTC Range A (Clean) 25.6 18 5.1 3.3 -- Available
FTTC Range B (Impacted) 20.5 10.4 4.3 0.8 -- Available
You guys quoted 18.
Obviously the profile reset needs to be done. The 10 day training thing comes in i'm sure but as i can't see any line stats i can tell if things will improve so thats my major Q and concern atm
17 REPLIES 17
Joshc
Re: New install
Good Morning Smiley
Glad to hear you have sorted the the router issues out!!
I have changed the profile for you as it was still on adsl!
We have to manually change the profile when a customer  upgrades to fibre and your upgrade question had only just come off hold
I apologise for the slight delay, you will see your speeds improve.
If there are any other questions I can answer , Fire away!
Chris
Legend
Fixes: 169
Re: New install
Your line is currently syncing at:
Downstream Speed 9.5 Mbps
Upstream Speed 1.2 Mbps
These are obviously below the estimates we provided, so I'd suggest going through our faults checker at https://faults.plus.net so we can see what needs doing.
taras
Re: New install
I'm hoping theres a fault Tongue because if it isn't about 30 properties are not gonna get great speeds Tongue (botched bduk and cab issue - due to the location of the cab).
I will raise a fault so we can check as to what is wrong (or not).
What are the line stats looking like(any room for improvement)?
taras
Re: New install
download tests are showing 8.9mb now. so thanks for the update on the profiles
is this normal though
"Estimated line speed:
    18Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-01-05 11:46:56
Current line speed:
    40 Mb "
I have put in a faults requested as suggested!
Joshc
Re: New install
Afternoon Smiley
The profiles have been changed however your lines are syncing a little low!!  Shocked
You have raised a fault which is the right thing to have done.
Its with the faults team now, they will get in touch with you in regards to the suggested fault.
Please keep an eye on this ticket number on your account (97188046)
Also If your speeds improve please let me know Smiley
taras
Re: New install
1. Best Effort Test:
Download Speed : 9.64 Mbps
2. Upstream Test:
Upload Speed : 0.97 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information"
I'm getting this when i do a "bt performance" test,  at http://www.speedtest.btwholesale.com
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Re: New install
Don't worry about the throughput tests at this stage.
Faults will do a detailed test shortly and confirm and engineer is required and we'll sort it for you.
 Tony T
taras
Re: New install
Sorry to be annoying but any update on whats happening ?
Joshc
Re: New install
Hey,
Good afternoon.
At the moment the matter is still with the faults team.
I have chased them for you and they will be in contact  with you shortly.
Thanks Smiley
taras
Re: New install
Thanks, I'm not worried that it will take a week or more to sort out but its the not knowing bit which is always frustrating. so thank you because if it isn't a fault, then its likely that most of our little village will get sub 15mbit fibre Tongue So I'm happy to be the guinea pig atm
Chris
Legend
Fixes: 169
Re: New install
I see we've got an engineers visit booked for this, let us know how it goes.
taras
Re: New install
Hi hes just been, basically no change to the speed .. its hovering around 7.8mbits Sad ..  there was some low insulation readings and the guy in the end changed the master socket.. The guy tested it down the road and that was reading 60/20. Im about 120m from the dp so its down to wiring.  Cry Cry Cry
Not sure what to do now Sad .
I have unlocked the spare hg612 so i will try and get some graphs done from the stats to see if theres anything we can do Sad
taras
Re: New install
line stats from the hg612
  Downstream Upstream
Attainable rate (kbit/s) 12836 1229
SNR margin (dB) 6 6.5
Line attenuation (dB) 31.5 0
Output power (dBmV) 8 10.5
and
Downstream Upstream Downstream Upstream
Line rate (kbit/s) 11202 1229 0 0
CRC errors 0 0 0 0
FEC errors 0 0 0 0
HEC errors 0 0 0 0
taras
Re: New install
should the ip profile be set at 8.12Mbs
