New install of FTTC - Unlimited Fibre Extra
loopyonion
I had ADSL changed to FTTC, journey started on 4th Jan, when BT scheduled the work. It did not go well, as I was the 1st install into a brand new FTTC cabinet. There was a problem. And, I had to wait for box repairs.
On the 24th I received a call from BT to say that they were activating today. The hub one went off, and, after an hour, then a power cycle. I had broadband back. I have NOT done a factory reset.
A rock solid 32mb DL, and 7mb upload. I did pay for the EXTRA package.?
I have checked speeds on BTW etc, shows no faults.
There is an open ticket at the minute, and a fault logged with plusnet.
So, the questions being:-
Is there a timescale before the speed/sync is upped?
Have plusnet (assuming it works like this) got the settings correct for the EXTRA speed?
Thanks in advance for your help.
Steve.
7 REPLIES 7
RealAleMadrid
Aspiring Hero
Fixes: 59
Re: New install of FTTC - Unlimited Fibre Extra
It is possible you have been put on the standard fibre product (40/10) instead of Fibre extra (80/20). What speeds does this checker give for your phone number?
https://www.btwholesale.com/includes/adsl/adsl.htm?s_cid=ws_furls_adslchecker
You should get the full speed straight away as soon as you are connected. PlusNet as a rule will not allow an order for Extra if you couldn't achieve the higher speeds so something isn't right.
loopyonion
BTW checker shows no faults,
DL of 32.5 out of 33.63 Mbps
UL of 8.37 out of 20 Mbps
RealAleMadrid
Aspiring Hero
Fixes: 59
If those figures are from the BT Wholesale speed checker then things are not looking good.Sad
Your Upstream IP profile is 20 Mbps, this is a fixed value and shows your are on Fibre Extra. It would be 10Mbps on standard fibre.
Your downstream IP profile is 33.63 Mbps which is much lower than expected for a line which should be capable of over 40Mbps.The speed estimates from the link I gave earlier would help to clarify what speed your line can support. If the speeds you are getting are much lower than the estimates, there must be some other problem that PlusNet need to investigate.
loopyonion
BT BROADBAND AVAILABILITY CHECKER
Telephone Number 017XXXX on Exchange SAINT HELENS is served by Cabinet 34
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 68.7 49 19.9 13.8 41.1 Available -- --
VDSL Range B (Impacted) 58.8 37 17.4 9.3 31.6 Available -- --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 3 -- 2 to 4 Available -- Yes
ADSL Max Up to 2.5 -- 1.5 to 5 Available -- --
WBC Fixed Rate 1 -- -- Available -- Yes
Fixed Rate 1 -- -- Available -- --
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- --
ADSL Multicast -- -- -- Available -- --
Premise environment
Status
Bridge Tap U
VRI N
NTEFaceplate N
Last Test Date 18-01-1970
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
This line is on a Market B Exchange.
For VDSL or G.fast Ranges A and B, the term "Clean" relates to a line which is free from any wiring issues (e.g. Bridge Taps) and/or Copper line conditions, and the term "Impacted" relates to a line which may have wiring issues (e.g. Bridge Taps) and/or Copper line conditions.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014. The Stop Sale date for IPstream is from 30-Nov-2012; the Formal Retirement date for IPstream is from 30-Jun-2014.
If the End User wishes to migrate from their current Broadband supplier they will need to contact the Broadband supplier they want to take service from to arrange for the service to be migrated.
Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number, NAD, UPRN or Access Line ID (ALID) check.
loopyonion
https://community.plus.net/t5/Library/FTTC-DLM-What-it-is-How-it-works/ba-p/1322799
When your line has been first provisioned, you may notice that your band is set to the ‘open profile’ which is likely to be either; 0.128M-40M or 0.128M-80M on the downstream and either 0.128M-20M or 0.128M-10M(depending on whether you’re on an up to 38Mbps or 76Mbps product). your line will be left on an open profile for 2 days initially to allow the line to adjust following the installation.
Fixes: 1,600
Welcome to the community forums Steve
I can confirm you're on the right wholesale product.
Banding for your line is: 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
It just looks like your line is syncing below expectations. If you've tried plugging your router into the test socket as explained here we'll need to arrange an engineer visit to further investigate. I'll update your fault ticket shortly too.
loopyonion
I did a factory reset this morning, also went direct into the test plate. ( i had the BT filter plate already fitted).
The results were better. UL stayed the same, DL increased.
Heading the right way, but still looks capped.
