New house move dropping connections
- New house move dropping connections
23-08-2018 10:40 PM
Moved house and connection dropping constantly for upto 30 seconds then be alrite for upto 30 minutes on average then drop again tried test socket changed ethernet cables reset modem rang plusnet yesterday guy noticed that im still on 40/10 at exchange so asked engineer to come change 80/20 just wondering if this has happened
Message 1 of 3
(439 Views)
2 REPLIES 2
Re: New house move dropping connections
24-08-2018 11:44 AM
Hi @thehypnootoad
After checking your service I can confirm the connection is provided on the correct product.
As you have completed the troubleshooting steps, if the issue is still evident please click here to raise a fault and reply so we can pick this up for you.
Thank you.
Message 2 of 3
(408 Views)
24-08-2018 4:41 PM
Thank you have raised a fault
Message 3 of 3
(395 Views)
