New fibre
- Re: New fibre
New fibre
15-12-2014 10:17 PM
Had fibre connected on 8th dec speeds all over the place disconnecting at least once a day.the red light is on on the router all other lights ok restart router all ok again. Sometimes all lights are green but cannot connect to Internet then all of a sudden all ok .should I reset the bt modem. I am using the plusnet router. Any help would be appreciated
Message 1 of 5
(778 Views)
4 REPLIES 4
Re: New fibre
15-12-2014 10:21 PM
have you raised a fault at https://faults.plus.net and what happened
Message 2 of 5
(406 Views)
Re: New fibre
15-12-2014 11:53 PM
I wouldn't touch the BT modem. DLM will interleave
Open a fault with plusNET
Message 3 of 5
(406 Views)
Re: New fibre
16-12-2014 10:24 AM
On Friday and Sunday there were a large amount of disconnections showing on your line. There have been some since then but nowhere near the same amount.
If you're still experiencing problems with your connection then as others have advised, the best bet is to open a fault ticket with us at http://faults.plus.net
Message 4 of 5
(406 Views)
Re: New fibre
16-12-2014 12:16 PM
Hi thanks everyone for your help,things seemed to have calmed down at the moment but will do as advised if things build up again.
Message 5 of 5
(406 Views)
