New fibre - slow downloads speeds
rizzlaking
So I've just upgraded to the full fibre package, engineer installed yesterday and left me with speeds of 69 mbs download 16 upload in the morning all fine.
I noticed after 12pm speeds seems slower so have since done numerous speed tests and am consistently getting 4mps download and 11mbs upload - I thought your download was faster than the upload what gives any ideas? I've tried resetting the router, thanks in advance.
James
Fixes: 167
Re: New fibre - slow downloads speeds
It's likely that the profile on our side needs a kick. I'll go and take a look now.
 Chris Parr
 Plusnet Staff
rizzlaking
Ok thankyou will wait to hear from you
Regards
Fixes: 167
Yep, that's sorted now. If you don't see an improvement in speed then just log in to your router and press disconnect, wait a short while and press connect.
 Chris Parr
 Plusnet Staff
rizzlaking
That's solved it - thankyou!
