New fibre, slow dl & ul
- Re: New fibre, slow dl & ul
18-04-2015 9:49 AM
I've recently upgraded from ADSL to Fibre 40/20. It was installed on 7th April and worked straightaway. I've done numerous speed tests over the past 10 days and the upload & download have never gone above 10Mbps which was little or no improvement on the speed I used to get. I wonder if a profile has not been updated? Or there's something else afoot? Could someone look into it, please?
Many thanks,
Ben
Many thanks,
Ben
Message 1 of 4
(567 Views)
3 REPLIES 3
18-04-2015 9:54 AM
Have you done a bt speed test http://speedtest.btwholesale.com/ just wonder what is your ip profile set to.
Message 2 of 4
(351 Views)
18-04-2015 9:54 AM
were those tests wired or wireless
Message 3 of 4
(351 Views)
18-04-2015 10:02 AM
A single disconnect/reconnect should sort this. Your current connection session started a minute or two before the speed profile updated on our side.
Message 4 of 4
(351 Views)
