New fibre install - need new router
- Re: New fibre install - need new router
12-11-2014 7:45 AM
Hello can anyone help. I had fibre installed Monday but when I olay Xbox one games on my router the nat is strict and people can. It join. I phoned plus net and they said they not able to help because it's a gaming issue.
I was going to try new router because I hear the one planet supply is not very good.
Would this router work from maplin
http://www.maplin.co.uk/p/tp-link-tl-wdr3600-dual-band-n600-wireless-cable-router-n31nq
Thank u !!
Thank u !!
Message 1 of 6
(972 Views)
5 REPLIES 5
12-11-2014 7:49 AM
It says for cable connections? My internet goes through phone line ?
Message 2 of 6
(559 Views)
12-11-2014 7:56 AM
it should do, what it means by cable is that it doesn't have an inbuilt modem so wouldn't be suitable for ADSL.
there are probably other choices out there.
Message 3 of 6
(559 Views)
12-11-2014 8:18 AM
Can anyone recommend any?
I don't really care about wireless range . Just would like to have an open nat with two xboxs not strict like it is now
Message 4 of 6
(559 Views)
12-11-2014 8:19 AM
Quote from: dvorak it should do, what it means by cable is that it doesn't have an inbuilt modem so wouldn't be suitable for ADSL.
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 5 of 6
(559 Views)
12-11-2014 9:50 AM
There's some discussion about suitable routers for fibre over here: http://community.plus.net/forum/index.php/topic,133737.msg1169161.html
Hopefully you'll find one suited to your needs.
Message 6 of 6
(559 Views)
