New fibre install, low downstream
baz10000
Just been upgraded today to fibre @ 40megs. Checked the speed and wondered what was going on.
Download = 6 megs. (Was getting 7 megs before with standard line.
upload = 18 megs. (was getting 0.2 before fibre installed.
Mmmm.
Adie:green changed topic to better title.
Fixes: 126
Re: Re: What has caused the speed drop and line speed change...?
Mod:note
Split topic for better visibility
Will Moderate For Thanks
Jhchicks
Re: New fibre install, low downstream
Welcome to the world of SLOW FTTC.
I get 20meg down and 7 megs upload.
PN think that everything is fine!!
Fixes: 136
@baz10000
The profile on our end was set incorrectly however I can see it's increased now so everything should be okay. Let us know if your still having issues
@Jhchicks
As per the responses in your other thread the speeds your getting are within the estimates for your line.
 Matthew Wheeler
