New fibre install - download speed < 2 Mbps - range 40 - 77 Mbps
- Re: New fibre install - download speed < 2 Mbps - ...
12-06-2015 10:47 AM
Just had fibre installed, but my download speed is ridiculously low (results from BTW):
Quote 1. Best Effort Test: -provides background information.
Download Speed
1.49 Mbps
0 Mbps 77.44 Mbps
Max Achievable Speed
Download speedachieved during the test was - 1.49 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
Upload Speed
9.63 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 9.63Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
The fibre connection was literally installed this morning, so this might seem impatient, but y'know 🙂
Re: New fibre install - download speed < 2 Mbps - range 40 - 77 Mbps
12-06-2015 10:50 AM
12-06-2015 10:55 AM
Quote Postcode:
Phone exchange:
DALKEITH
Estimated line speed:
1.5Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-05-04 12:47:20
Current line speed:
2 Mb
12-06-2015 12:56 PM
12-06-2015 1:10 PM
12-06-2015 1:17 PM
12-06-2015 1:24 PM
It says it is unavailable for me....
12-06-2015 1:35 PM
Unfortunately I'm still getting the same speed test results on BTW, even though my current and estimated line speeds have been updated. Will try restarting the OR modem again later and see how that goes.
12-06-2015 1:38 PM
Just restart the router or select disconnent then connect from the menu
12-06-2015 1:44 PM
12-06-2015 2:31 PM
