New fibre fault
New fibre fault
Hi PN staff, I've just reported a fault. After a period of dodgy speeds, this morning my speeds are way down & the BTW tester is showing a fault which I have reported.
If possible, in order to speed up the resolution of the fault, could one of the EXCELLENT PN forum staff please take ownership?Huh
Thanks in advance,
NJ
Fixes: 162
Re: New fibre fault
Testing your line is showing that it's in sync within the estimates and the throughput is only very slightly below where we'd expect it to be. What speeds have you have previously as the estimates for your line are:
eatured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 50.8 37.1 11.3 7.4 34.3 Available -- -- Yes --
and the current sync is:
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 41.7 Mbps
Upstream Speed 12.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 749.8
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence ; 00:00 to 23:45
Interference Location Customer Premise
Interference Observed In Days 14
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-60M Downstream, Error Protection Off - 0.128M-12M Upstream, Error Protection Off
Time Stamp 2017-05-26T12:00:00
 Chris Parr
 Plusnet Staff
Re: New fibre fault
Thanks Chris for the prompt service.
I've just finished working with a buddy at my end & it appears that it's a problem with my laptop. Basically it's slightly knackered! Now to start looking for a replacement, deep joy.
Kind regards,
NJ
Fixes: 162
Re: New fibre fault
No worries, I'll drop the ticket back over to you. If you reply it'll come straight back to the forum team so it'll only be us dealing with it.
 Chris Parr
 Plusnet Staff
