New fibre customer
- New fibre customer
New fibre customer
20-08-2017 1:43 PM
Re: New fibre customer
20-08-2017 2:59 PM
Yes you can with the filter and no nothing needs to be done.
I don't know if you've ordered a router from PlusNet, or you have a VSDL one already.
All I needed to do was to swap the routers around and wait 10 minutes - pretty easy really.
20-08-2017 4:35 PM
Cool. Plusnet are sending a router but I prefer to use my existing asus one.
thanks
21-08-2017 2:46 PM
21-08-2017 3:03 PM
Post the model of your router, someone here can check for you.
If it isn't, you'll have to use the PlusNet one in the short term - but it'll get you by in the meantime.
If your current router is VDSL compatible then fine, but you'll probably have to configure it I guess - people on here will help.
Otherwise you've got the option of using the PlusNet router if you get on with it, or you will have to buy another router which supports VDSL.
When we got fibre I chucked the old router away, as it was no good anymore. Not had any issues with the PlusNet one, so I would see how you go with it initially.
21-08-2017 6:40 PM
I've got a ASUS DSL-AC68U. The box says it's ADSL/VDSL so I assume it will work but as you say may need some config changes
21-08-2017 6:54 PM
PlusNet provide the settings required for third party routes in their Help pages.
