New fibre connection speed dropping daily
- Re: New fibre connection speed dropping daily
31-10-2017 9:30 PM
Hi.i am after some help.im currently on fibre 38/2 i have had this now for about 2 months. But in the last 3 weeks the connection is dropping off.wired pc and on a wired tv iplayer.so every 20 mins every night in between the hours of 6pm and 9 pm it will drop for 2 to 3 mins.while writing this on my phone i have seen the yellow triangle in bottom righ side of my pc.no connection and iplayer as stopped once.
Message 1 of 3
(495 Views)
2 REPLIES 2
01-11-2017 10:24 AM
Sorry to hear you're having issues with your speed.
I've tested your line and it's not showing any issues..
By drop do you mean the connection goes entirely or do you mean the speeds drop?
Message 2 of 3
(446 Views)
28-11-2017 7:36 PM
hi,sorry it as taken awhile getting back to you. iv been keeping a tab on the drops. I will loose connecting entirely for about a minute then it as reconnected that's the pc on a wired connection. The xbox is on a wired connection too upnp not successful message keeps being displayed will get back in a couple days
thanks
Message 3 of 3
(401 Views)
