New customer - not happy
- Re: New customer - not happy
16-09-2015 5:02 PM
I've moved house and decided to go with Plusnet. It took over 2 weeks for the BT engineer to come to get the fibre connection working and the Openreach box installed.
That was yesterday and although I wasn't home my wife assures me that it was working. However since late afternoon we've had no DSL connection. I raised a "Question" early this morning and from following the instructions it seems that we have no dial tone for the phone either. After looking at some other posts on this forum for Fibre and Telephone, I'm not very optimistic about how long things will take to resolve themselves.
One of the reasons for moving house was that I'd be able to work from home, but it looks like that isn't going to happen for some time now and I'm starting to question if going with Plusnet was a good idea.
Message 1 of 8
(1,284 Views)
7 REPLIES 7
16-09-2015 6:41 PM
You would be better off phoning them than waiting for your ticket to be responded to do it can take 2 working days. Personally if you believe there is a line fault then you should call them and get a fault raised while you are on the phone.
Message 2 of 8
(754 Views)
17-09-2015 12:34 PM
I raised the ticket via the web since I couldn't find a number to call That was at 6:20 yesterday. Since then the last update was
"The problem you've identified with your phone line is the likely cause of your broadband problem. We need this fixing before we can investigate further.
As we're your phone provider, we'll investigate and report this problem for you."
I'm not very optimistic on how long it will take as it took 2 weeks to get the Openreach engineer here.
Message 3 of 8
(754 Views)
17-09-2015 12:57 PM
I've picked this up for you.
The testing has completed on your telephone line and it appears that Openreach tests detected a disconnection in the local network between you and the cabinet.
A fault has been raised for a network engineer to investigate and this can take upto 48 working hours to complete with an estimated resolution therefore of 22nd September.
Hopefully once the disconnection is resolved, your Fibre service will start working again.
I've updated the support ticket you raised to reflect the same.
Message 4 of 8
(754 Views)
21-09-2015 10:20 AM
Thanks for following up on this for me.
I got a call Saturday morning from the BT engineer to say that he'd fixed the problem - and sure enough everything is working!
Message 5 of 8
(754 Views)
21-09-2015 10:54 AM
Glad to hear all is now resolved. Thank you for letting us know.
Message 6 of 8
(754 Views)
22-09-2015 12:54 AM
old customer not happy looking at a sat system at moment
Message 7 of 8
(754 Views)
22-09-2015 3:05 AM
Glad to hear it's sorted. Looks like a usual Openwoe / Openwoe subcontractor issue. (Once a KC engineer showed up to fix a line fault, and I lost 1/3 of my broadband sync...)
You can't really blame Plusnet for your local area's overcontention, historically that's BT's fault for not sufficiently provisioning your area with copper pairs - and it's Openreach's fault for not planning to add more for future demand.
Go with Tooway if you need decent bandwidth and monthly allowance. Expect pings well over 1 second though, any kind of latency-critical gaming is out the window on any sat service.
Quote from: philto old customer not happy looking at a sat system at moment
Message 8 of 8
(754 Views)
