New customer - how often should DLM disconnect the system?
FIXED- Subscribe to RSS Feed
- New customer - how often should DLM disconnect the...
24-02-2020 7:05 PM
Trying to get an idea on stability - I was connected Tuesday, the router showed a disconnect at just after midnight that night, then at 2.30am the following night (Thursday morning), both times with different sync speeds. it has remained connected since then. I was under the impression the DLM would try different sync speeds for up to two weeks and would adjust regularly, I am not complaining as the origional two sync speeds were far lower than the current, apparently stable one, just trying to get a handle on the process...
Fixed! Go to the fix.
24-02-2020 8:47 PM
@chubsta maybe this will help, it was posted by @Pettitto - FTTC DLM - What it is & How it works
https://community.plus.net/t5/Library/FTTC-DLM-What-it-is-How-it-works/ba-p/1322799
