New customer- can’t authenticate connection on router
Wendywitchwoo
Hi
I’m a new customer and can’t connect my router the internet.
It’ll connect when I reset to username setup@plusdsl.net; but I have no internet access (bar the plus.net site)
I disconnect and change credentials to {myusername}@plusdsl.net with correct password but it won’t authenticate...
Is it definitely the password you use for logging into plus.net? Or some weird thing like using the hubs admin password or router MAC address or something like that?
TIA
4 REPLIES 4
Fixes: 392
Re: New customer- can’t authenticate connection on router
@Wendywitchwoo sounds like your account hasn't activated automatically.
@Gandalf seeing as you're around can you assist please ?
Wendywitchwoo
It’s working now. Perhaps I was just being too impatient. Looks like it came on around 01:00. Was told could take up to midnight so only an hour late 😃
steveocee
That's not too bad. Mine was "only" 11 hours late. #firstworldissues
www.steveocee.co.uk
SammyM
Fixes: 96
Hello @ Wendywitchwoo,
Thanks for getting in touch and we are glad to hear you are now connected. Please come back to us if you need any further assistance.
 Sammy M - Sheffield Team
