New customer - broadband not working!
- Re: New customer - broadband not working!
21-04-2021 8:20 AM
I need the internet for work so this is far from ideal!
Any help?!
21-04-2021 8:33 AM
Try a factory reset by pushing a paperclip or similar into the reset hole that you will find on the hub. Keep the switch closed for about 30 seconds.
21-04-2021 8:35 AM
21-04-2021 8:51 AM
@Karin what 'username' is showing on the router?
21-04-2021 8:56 AM
21-04-2021 9:05 AM
21-04-2021 9:05 AM
21-04-2021 10:05 AM
@Karin I assume the 'where do I find this' question was aimed at me? Sorry, I don't know your router, so can't answer that, but hopefully either @dvorak or @Baldrick1 can point you in the right direction.
21-04-2021 10:15 AM
Username and password are located on the router - it will be admin
Once logged in go to:
Advanced Settings > Broadband
what is Broadband Username?
21-04-2021 6:32 PM
21-04-2021 6:37 PM
@Karin In that case, it needs changing to 'yourusername'@plusdsl.net with the correct password.
To do so, disconnect the DSL cable while still on that page, change as required -click any 'save' button visible, and then reconnect the DSL cable.
Report back, whether it works or not.
