New customer. No Internet
- New customer. No Internet
21-10-2018 9:30 PM
Re: New customer. No Internet
22-10-2018 3:46 PM
Same has happened to ourselves except connection date was 19 Oct have spent over 3 hrs on phone trying to deal with Plusnet (about 15 mins of this was actually talking to 3 different people) rest was on hold actually trying to get through. Turns out my original router is the wrong one and whoever done initial transfer forgot to order router now have to wait again for correct one to be posted out as bt homehub 5 that did work, some how has stopped working, Just seems to be lies and fob offs at each call
22-10-2018 4:25 PM
Hi @sioidestrocio ,
Thank you for your message and welcome to our community.
I've checked into your account and it appears that you are now up and running and are now online, as of this morning, as the below graph indicates:
Please let us know if you're still experiencing any sort of issue and we'll be happy to investigate further for you.
22-10-2018 7:14 PM
22-10-2018 8:59 PM
@Vonnymcm That is very poor from Plusnet support, the Plusnet Hub1 router is effectively the same as the BT home hub5 so if you change the username and password to your Plusnet credentials it should work on your Plusnet connection.
22-10-2018 9:47 PM
23-10-2018 12:26 PM
Hi @Vonnymcm, while I appreciate the routers are very similar, as it is not a router we provide it's technically correct that we wouldn't support it, although we'd be able to advise the information you'd require to input in the router.
If customers are looking to set up a BT router on a plusnet connection, I'd generally direct them to this thread: https://community.plus.net/t5/My-Router/Use-a-BT-Hub-2-3-4-or-5-on-a-Plusnet-connection/td-p/1192234
Is your router still plugged in now? As the light you've mentioned on our router, would suggest an authentication failure (If it was a solid red b as opposed to a flashing b) and I believe I've found a cause of this on your account.
Having said this, testing your line is now showing the router is out of sync, which may be a different problem/fault on the network, or it could just be that your router is not currently plugged in.
23-10-2018 12:31 PM
