New customer, Hub One syncing 9.1mbs is that all?
Digirium
Hi, my Unlimited Fibre connection was activated yesterday.
Hub One syncs at 9.1.mbs will it eventually sync up at between 33-40mbs or is intervention required?
Is it possible that at the cabinet my line has not been lifted on to fibre by BT yet and currently syncing to the exchange instead of the cabinet?
10 REPLIES 10
Fixes: 1,483
Re: New customer, Hub One syncing 9.1mbs is that all?
what does this say https://www.plus.net/my.html?action=data_transfer_speed for current line speed?
Digirium
Telephone number:
    xxxxxxx1052
Phone exchange:
    Hxxx xxxxxxE
Estimated line speed:
    40Mb (This may vary between 32.4Mb and 48.3Mb) - Checked on 2015-11-13 10:35:55
Current line speed:
    9.1 Mb
Strat
Fixes: 565
It needs a profile kick.
Maybe one of the Plusnet CRT can take a look tomorrow or you could try Chat when they're open for business.
jelv
Fixes: 10
Before you can say that we need to know what the BT diagnostic speed says for the IP Profile.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Digirium
jelv
Fixes: 10
Ye Gods - what sort of rubbish is that?
For your connection, the acceptable range of speeds is 20Mbps-9.18Mbps
If you haven't done so already I suggest you raise a speed fault and comment on that ludicrous range: http://faults.plus.net
Digirium
Thanks for replies fault ticket raised.
Digirium
Any Plusnet staff able to intervene and remedy this fault for me please?
Ticket ID 115525196
Many thanks.
SteadVex
i'm not sure if things are faster now, but for what its worth it took about 10 days for mine to get stable & fast
it was the same with my previous supplier for fibre too
jelv
Fixes: 10
There's no Plusnet staff on these forums over the weekend. If you haven't heard anything by tomorrow morning posts again then.
