New customer (10 days) and line speed well down from BT infinity and estimate
elrao
Was a BT Infinity customer from day 1 and although I was on infinity 2, my max speed was 39-40 Mb (actual downloads at 4.7-4.8 MB/s).
Switched to PN unlimited 76Mb service 10 days ago.  My estimated speed was 40-60, so I thought it was worth a punt to go with the 76Mb option over 38 in the hope I'd get 50+.
Unfortunately I'm getting a lot less and a lot less than I got from BT.  Current speed reported as 28.4Mb, which matches my real download speeds in the range 3.2-3.4MB.
Telephone number:
01277xxxxxx
Phone exchange:
BRENTWOOD
Estimated line speed:
60Mb (This may vary between 39.8Mb and 60Mb) - Checked on 2016-02-03 15:58:59
Current line speed:
28.4 Mb
Not happy at the moment!!
Fixes: 167
Re: New customer (10 days) and line speed well down from BT infinity and estimate
I've tested your line and it's come back with a potential issue on the phone service, however the fault type it's reporting is commonly caused by something plugged in to the line at your side. Could you unplug everything from the line and let me know when that's done so I can retest and see if we get the same results?
Downstream Speed 32.4 Mbps
Upstream Speed 7.0 Mbps
Voice Line Test Result Voice fault suspected - contact Voice CP to progress copper issue
Test Result: Fail - Fault located at customer apparatus
Description: FAULT - Loop (Rectified)
 Chris Parr
 Plusnet Staff
elrao
Thanks, can't unplug everything for very long though - as all we have plugged in is the house phone and the burglar alarm.  Is there a way to arrange to have this test done when I am home and can unplug everything there and then?
2 years ago we had a new line fitted from the mast to the house, and 6 months ago we had a new master socket fitted - with a single cable from the junction box on the front of the house to the master socket (no connections).  House phone is then connected directly to the filtered side of the master socket and alarm is run as a slave off the back of the filtered side.
It is EXACTLY the same setup we had before, apart from swapping the BT open reach modem (with BTHH4) for the One Hub on the broadband side of the master socket.
Can however confirm speed has improved slightly, am getting 3.7MB/s real downloads (but still over 1MB slower than BT) and well under my estimated speed of 40-60Mbps
elrao
So I thought I would raise a support ticket, as your chat is offline (and probably disabled from my work PC anyway) and if I call I know they will only want me to start un-plugging things which I can't do as I am at work.
Turns out you can't raise a ticket (and haven't been able to for some time), all this talk about great customer service - am yet to see it!!
I figured out how to raise a fault ticket - got all the way through to the last step and then got a website error!  WORST SYSTEM EVER.
BrightonRock1
Quote from: elrao
Chat is working here but are you using an adblocker or ghostery? You may need to turn them off to get chat to start..
I do wish PlusNet would either change the coding of that page or, at the very least, put a note on the page saying that initiating chat can be prevented by many common browser security measures.
elrao
Yeah, like I said it is probably disabled on my work PC, we aren't allowed any kind of email or chat programs ... But forums work!
Tried to call, now I've come home earlier...30 minute wait time...5 people ahead of me on chat.
mav:quote
elrao
If anyone from plus net is reading this, I've plugged the supplied micro filter into the test socket and reconnected the hub one. Nothing else connected.
Fixes: 62
what are the sync speeds
elrao
With everything disconnected, including the modem, it still showed the same fault.
I then disconnected the master socket and it changed to an external fault, reconnected master socket and fault switched back!
As it showed an external fault, they've raised it to "the supplier" to investigate.  I did see an openreach guy working on my cabinet the day I switched and the day the line speed dropped, coincidence?
All connected back up now, and getting same 31.2 connection.
Plusnet Staff
Plusnet Staff
Fixes: 117
Hello there. It's strange, but the fault location of these loop faults can vary each time we test the line. Did you run this test yourself using our phone troubleshooter online? If it found a fault with the master socket disconnected, then the issue would lie externally and our suppliers usually respond to these faults within 48 working hours. I'd recommend contacting us via webchat for an update in a couple of days if the issue still persists.
Hope this helps
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
elrao
All tests were run by Hayley on the support team, was chatting to her throughout on web chat (on my phone - not the easiest!!).  She raised a fault as soon as she saw it come up as an external fault, 27 hours left on the clock ....
dick:quote
Plusnet Staff
Plusnet Staff
Fixes: 117
I've checked the fault for you now and our suppliers would like us to arrange an engineer visit to investigate further. As you've tried disconnecting your master socket and the problem still persists, we'd like to arrange this engineer. I've updated your ticket with more detail.
 Plusnet Staff
elrao
Quote from: Anoush
And I have replied ...
elrao
Having checked the line, the connections in the cabinet, connection on the pole, the gable of the house .... it turned out to be a faulty BT master socket.  Replaced and no fault, now back over to PN to sort out the line speed issue!
Plusnet Staff
Plusnet Staff
Fixes: 117
Hello there. The line is syncing at  32.4 Mbps, which is under your speed estimate. This needs to be raised as a broadband now, unfortunately. If you could raise it at http://faults.plus.net, our faults team will pick it up and be in touch shortly.
 Plusnet Staff
