New connection today
FIXED- Subscribe to RSS Feed
- New connection today
13-05-2021 10:57 AM
Fixed! Go to the fix.
Re: New connection today
13-05-2021 11:09 AM
@Alan54 Plug the router into the BT socket - the NTL one is a dead duck.
It may be an idea, though, not to do that until you are advised the Fibre connection is 'live'.
13-05-2021 11:20 AM
13-05-2021 11:21 AM
Should be, yes.
13-05-2021 11:22 AM
14-05-2021 8:12 AM
14-05-2021 8:14 AM
Have you had confirmation that the service is available?
14-05-2021 8:18 AM
14-05-2021 8:21 AM
Two suggestions: What username and password is the router showing? try ringing PN and ask them what the situation is.
14-05-2021 8:24 AM
14-05-2021 8:26 AM
Try reconfiguring the Hub6 - details are on the 'My Router' board.
14-05-2021 8:55 AM
14-05-2021 11:00 AM
Or, if you received a Plusnet Hub One, why not try plugging that in and entering your details? If it does connect, then there's somehing amiss with the BT Hub?
14-05-2021 11:11 AM
Everything sorted now. Connection is up and running. Thanks for all help.
