New connection half the speed
imposter63
Just had fibre enabled today signed up for up to 80 meg Unlimited Fibre Extra but only getting 46 ,will it speed up ?
rongtw
Fixes: 12
Re: New connection half the speed
PN may not have updated your profile yet , have rebooted your router ?
Browni
Aspiring Hero
Fixes: 45
imposter63 wrote:
will it speed up ?
Maybe.
You can see the estimated speed for your line here.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
imposter63
Have re-booted router several times , changed standard router for a different one but still the same
Line is supposed to handle 72.7 to 80
Fixes: 33
How are you testing via a wired connection or WiFi?
Have you logged into the router to see your sync speeds - posting the details from the Helpdesk tab, making sure you obscure your username and SSID might hel get you soe more detailed help.
Fixes: 162
Looking at your estimates your line showing be synced between 72.7 and 80Mb/s
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 80 72.7 20 20 -- Available -- -- -- --
Testing your line is showing it's actually connected at 41.7Mb/s, so something isn't right there.
est Outcome Code GTC_FTTC_SERVICE_0001
Description GEA service test completed and no fault found but unable to check for customer equipment connected to modem.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 41.7 Mbps
Upstream Speed 15.5 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Detected
Cross Talk Not Detected
Estimated Line Length In Metres 573.1
Upstream Rate Assessment Reasonable
Downstream Rate Assessment Low
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence From 09:45 to 11:15
Interference Location Customer Premise
Interference Observed In Days 2
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
I'd advise getting this reported to us as a fault at https://faults.plus.net - let us know here when you've done so and we'll get this pushed through.
 Chris Parr
 Plusnet Staff
imposter63
Ok reported this as a fault
Fixes: 20
How many telephone sockets do you have?
The "Bridge Tap" the test detected could possibly be due to unfiltered extension sockets (although the test results do also say No for "Home Wiring Problem").
Fixes: 162
I've just checked the fault and the next step will be to book an engineer visit, I've updated the fault ticket with this info so if you can reply there with your availability we'll get this progressed and booked.
 Chris Parr
 Plusnet Staff
