New WiFi password not recognised after changing to BT Smart Hub
I have followed the well trodden path of replacing my PlusNet One modem with a BT Smart Hub 6A (FTTC). My (wired pc) is functioning well having installed the Smart Hub using the directions posted by several people on here.
I am however, left with a problem, when I try to connect my devices using WiFi,  I get an incorrect password message despite using the new password that came with the Smart Hub and checked the password is correct according to the WiFi advanced settings page. I haven't seen anybody else report this problem on this website.
Any suggestions
2 REPLIES 2
Re: New WiFi password not recognised after changing to BT Smart Hub
Problem has resolved itself after about 30mins, I tried again and it worked fine on all devices
Fixes: 79
Great to hear its sorted out @poacmn.
Do get back in touch if there is anything else we can help with.
Thanks.
 Maddy S
