New User-Line speed Also dropped to 21Mb
- New User-Line speed Also dropped to 21Mb
26-05-2016 3:22 AM
Hi have posted here https://community.plus.net/t5/Fibre-Broadband/line-speed-dropped-to-21-Mb/m-p/1337778#M39297 but think I really should've started own thread so........
My line speed has dropped to 21Mb as stated,in the previous post I noticed the solution from Chris Parr was a Plusnet Profile Mismatch,is it possible the same has happened to my line?
Could this be checked and corrected if so
max attainable 13763/51633
data rate 39993
snr14.4/9.7
att 19.2/17.7
Re: New User-Line speed Also dropped to 21Mb
26-05-2016 12:49 PM
Moderators Note
Thread locked in favour of linked post with PN reply.
26-05-2016 12:55 PM
I've just looked into this and the speed profile is set correctly so it doesn't appear to be due to the same issue.
Were you connecting over WiFi when you observed the 21mb result?
