New Subscriber - Phone switched overnight but no advice about internet switching
- Re: New Subscriber - Phone switched overnight but ...
04-09-2015 9:44 AM
I just switched from BT fibre to Plusnet fibre and phone package. My phone was switched overnight and of course my BT Broadband has stopped working.
I have received advice that my plusnry router has been sent and that my Internet should be available from 5th, I have not however had any notification about an engineer visiting ( I don't actually need it as i have a TPLink 9980 that I was using on BT)
Is it just a matter of them switching me over at the exchange ?
Message 1 of 7
(782 Views)
6 REPLIES 6
Re: New Subscriber - Phone switched overnight but no advice about internet switching
04-09-2015 9:53 AM
If you already have fibre then there is no need for a engineer unless there is a problem, all you need to do is plug in the plusnet router or configure your own router and away you go that is assuming the switch over has been done and plusnet have thrown the switch their end.
Message 2 of 7
(589 Views)
04-09-2015 11:24 AM
I never got a notification when switching in over a year ago either. In fact I got told an engineer would be coming (which I ignored being a savvy user). When I got home I just decided to switch my router over on the off-chance and the service turned out to be live and ready.
Message 3 of 7
(589 Views)
04-09-2015 11:53 AM
Just an update on this.
I got through to [mremoved] in customer support and explained the problem. Mark checked things his end and said that the part of the system needed to get me up and running was down, but that he would call back when he was able to access it again.
True to his word Mark did call me back and went through various settings with me. I had been using a TP Link 9980 with my BT Fibre without any problems but when I entered my Plusnet configuration details it would throw up a "Unknown Error" message.
Mark was patient whilst I got my old BT Homehub and Router back out of the box and set it up again. This sorted the problem and I was able to connect to the Internet.
Once up and running I had another try with the TP Link, still no joy and still getting the "Unknown error" message. I did a factory reset of the TP link and re entered all my details, it then connected without a problem.
Really pleased with the support that I received, I'm getting 34 down but only 1.8 up, I'm hoping that the up speed increases over time as i was getting about 15 up with BT.
Once again, great customer support 🙂
dick:csa
dick:csa
Message 4 of 7
(589 Views)
04-09-2015 11:57 AM
From those speeds it seems likely that you have ordered the standard fibre package not the fibre extra so you will be on 40/2 speeds
Message 5 of 7
(589 Views)
04-09-2015 12:29 PM
Message 6 of 7
(589 Views)
04-09-2015 12:45 PM
Ah, Ok, misread it as 40/20
Thanks for the feedback.
Message 7 of 7
(589 Views)
