New Signup!
- New Signup!
New Signup!
08-02-2016 10:42 AM
I've just signed up to Plusnet having moved from a BT Infinity service. With my current service, I use the BT supplied BT Openreach (Huawei) modem with my own router behind it (i.e. a cable style router).
I'm wondering if anyone can tell me if the equipment I'm going to receive from Plus will allow me to continue this setup - for example, do Plus still provide a separate modem and router package or do their routers have the VDSL modem built in? Sorry for the dumb question but I'm struggling to find a reference to this on the website.
Thanks in advance!
fb.
Thanks in advance!
fb.
Message 1 of 7
(1,202 Views)
6 REPLIES 6
Re: New Signup!
08-02-2016 10:46 AM
They will supply an all in one router/modem which is equivalent to a HomeHub Type A although you could actually continue using your existing equipment by changing the login information in the router
Message 2 of 7
(472 Views)
Re: New Signup!
08-02-2016 10:51 AM
Thank you Oldjim.
Message 3 of 7
(472 Views)
Re: New Signup!
09-02-2016 6:30 PM
@FlamingBadger
This may help if you wish to use your current set up, however the equipment sent out by Plusnet will be the same as the BT Hub 5 just rebadged as Plusnet (BT own Plusnet )
https://community.plus.net/forum/index.php/topic,135840.0.html
Regards
NE
Regards
NE
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 4 of 7
(472 Views)
Re: New Signup!
16-02-2016 9:24 AM
Many thanks for the pointers NE
Message 5 of 7
(472 Views)
Re: New Signup!
16-02-2016 2:49 PM
No problem
Hope you get set up okay!
NE
NE
Message 6 of 7
(472 Views)
Re: New Signup!
24-03-2016 11:01 AM
For those interested, Plus works perfectly using the existing BT Openreach modem
Message 7 of 7
(472 Views)
