New Sagemcom 2704n Moden Fibre sent & doesn't work with port forwarding to the camera
- New Sagemcom 2704n Moden Fibre sent & doesn't work...
02-06-2015 7:24 PM
Hi there
We have been sent a new modem , the Sagemcom 2704n i assume, and we had a technicolor before.
I have copied over all of my port forwarding and opening TCP/UDP Ports (8k, 9k, 10510) so we can see our camera on kweye/meye iphone app.
Unlike the technicolor one, it didn't ask me to put the ip of the DVR into the port forwarding process.
Ever since the new modem, it will work for like 1 hour and then in the app it just says "Connect to server fail/ Failed to connect".
When I go into the modems IP it says the same exact input that I make and nothing changes.
Only once I go into the Port Forwarding Edit and without changing anything click "Apply" it then starts working again.
Can anyone help?
Can anyone help?
Message 1 of 7
(1,766 Views)
6 REPLIES 6
Re: New Hub5 Moden Fibre sent and doesn't work with port forwarding to the camera
02-06-2015 11:34 PM
Any1 can help?
Message 2 of 7
(1,149 Views)
03-06-2015 7:36 AM
Try deleting the existing application ports and reading them again. I had the same problem when the IP of the camera changed
Message 3 of 7
(1,149 Views)
03-06-2015 12:04 PM
Ive completely removed the old input and added it again but it still does it.
I find it strange that the old router asked for the IP input but this one doesn't.
Message 4 of 7
(1,149 Views)
Re: New Sagemcom 2704n Moden Fibre sent & doesn't work with port forwarding to the camera
03-06-2015 10:01 PM
if you have static ip setup on your cctv then it won't work as it have to be dhcp for it to be able to be picked up by the router attached devices, then it can be added to port forwarding.
it's rather annoying that some cctv need to be rebooted every so often and the ip can be randomly assign and it's back to square one again.
Message 5 of 7
(1,149 Views)
03-06-2015 11:20 PM
So there is nothing i can do with the current plusnet router?
I know the camera support except the router to be static so i assume the DVR has static ip?
Is there a separate router i can purchase that makes it possible for me to have it work?
Message 6 of 7
(1,149 Views)
04-06-2015 6:36 AM
If you can see the DVR on the list of attached device then the problem may be else where. Do you know IP address of the DVR?
Message 7 of 7
(1,149 Views)
