New Plusnet Customer - Woeful Speed!
- New Plusnet Customer - Woeful Speed!
02-04-2015 7:33 PM
New Customer today - engineer has been and connected up, took a while to get connected for some reason but his line test/txt message came back saying line supports 80m/20mb
Upload is nicely sat at about 18-19mb which is great. Download is stuck at about 12mb which has now stablised....
Should I be worried, or does it really take 5 days for the line to become stable - the box is literally at the end of the street - 200m max!
Any ideas?
Rich
Any ideas?
Rich
Message 1 of 8
(894 Views)
7 REPLIES 7
Re: New Plusnet Customer - Woeful Speed!
02-04-2015 7:37 PM
If the engineer tested and could see 80/20 then I'd expect you to be getting close to the full speed on your Up to 38Mb product.
Message 2 of 8
(587 Views)
02-04-2015 7:37 PM
This is what I see in the Router settings:
Your Plusnet adviser may ask you for the following information:
1 - Product name: Plusnet Router
2 - Serial number: N7150281M006371
3 - Firmware version: 7.273.1_F2704N_Plusnet
4 - Board version: F@ST2704N
5 - Mode Fibre
6 - Uptime: 0 days 07:10:43
7 - Data rate: 100M/100M
8 - Maximum data rate: 100M/100M
9 - Noise margin: -
10 - Line attenuation: -
No Line Stats which is a bit odd.....do you suppose there could be a fault Chris?
5 - Mode Fibre
9 - Noise margin: -
Message 3 of 8
(587 Views)
02-04-2015 7:38 PM
Having tested the line I can't see any issues at all. You won't see the line stats in the router on a fibre connection.
Downstream Speed 80.0 Mbps
Upstream Speed 20.0 Mbps
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Can you ensure you're testing via an ethernet cable?
Message 4 of 8
(587 Views)
02-04-2015 7:39 PM
Message 5 of 8
(587 Views)
02-04-2015 7:40 PM
Indeed I am - Direct connection....
Message 6 of 8
(587 Views)
02-04-2015 7:41 PM
Message 7 of 8
(587 Views)
02-04-2015 7:50 PM
Message 8 of 8
(587 Views)
