New Modem/Router?
- New Modem/Router?
New Modem/Router?
25-11-2015 10:15 PM
Hey Guys,
I was wondering if Plusnet allow us to use our own router/ modems and if so can you guys recommend some for me?
Theo
Theo
Message 1 of 4
(1,424 Views)
3 REPLIES 3
Re: New Modem/Router?
25-11-2015 10:45 PM
Short answer is "yes". I can recommend Billion routers, but they are not for non-technical people, if you want plug'n'play you might be better off with the Plusnet provided router.
Message 2 of 4
(601 Views)
26-11-2015 8:45 AM
If you are looking for a VDSL router (which does away for the need of the BT Openreach Modem) then this list may be helpful:-
http://forum.kitz.co.uk/index.php/topic,14436.0.html
I have the Netgear D7000 which was simple to set up but still has advanced features if you need them.
Message 3 of 4
(601 Views)
26-11-2015 12:27 PM
Message 4 of 4
(601 Views)
