New Here
Twoterriers
New Here
I just moved from John Lewis Fibre over to Plusnet and in the process I've lost half my speed ! It was supplied by Plusnet too so is anyone else having this problem, please ? I don't see how it can be any different at all !!
Cheers,
Lynda~
"Children are for people who can't have dogs"
rongtw
Fixes: 12
Re: New Here
hopefully one of PN staff will see this and have a look
Twoterriers
Re: New Here
Hoping so, too. Cheers.
Lynda~
Fixes: 62
Re: New Here
just a thought - were you on fibre extra with John Lewis and now on Unlimited Fibre with Plusnet - your router reported speeds would confirm
Twoterriers
Re: New Here
No, Jim. I don't live in an area where I can get the super-dooper speeds so it has always been the basic fibre up to 32mb I think it's always advertised as.
Cheers,
Lynda~
Plusnet Staff
Plusnet Staff
Fixes: 116
Re: New Here
Hi there @Twoterriers I'm sorry to hear your speed has decreased since joining Plusnet.
I'm testing your line and I'm seeing your router in sync at 13.5 Mbps which unfortunately is just within your estimated speed range of between 13.5 Mbps and 19.6 Mbps.
I'm not identifying any faults so we'd be hard pressed to get a fault raised to our suppliers as the line is performing within expectations. Honestly, no changes would have been made in the transfer from your previous provider.
My best suggestion would probably be to try internal checks by plugging your router into the test socket, explained here: https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
If this doesn't help and if the speed drops down further then it'd be outside of the estimate and you'd be able to raise a fault at http://faults.plus.net . I apologise for the inconvenience caused.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
Twoterriers
Re: New Here
What hasn't been explained, Anoush, is that you guys provide John Lewis who provided me on the same line regularly at 19+ which I can prove as I have an app with records.
So I'm not understanding how I lose almost 50% of my speed by moving to you direct. I don't have a master socket as pictured. The one I have is a new one the John Lewis engineer installed with a double frontage and it's called a Master Socket 5C and it doesn't have screws I can undo.
You sent an email over to me yesterday to advise my speeds were averaging 11.1 against what it should be but offered no more assistance, so pretty much just advising it is slow !!! I knew that !!
Not sure what else I can do now. Nothing has changed from using John Lewis aside from the router and you taking over the line direct !
Lynda~
Twoterriers
Re: New Here
I just ran 2 X BTWholesale speedtests-results as follows:
21/3 Ethernet
Download 12.86
Upload 0.89
Ping 25.25
21/3 Wifi
Download 12..86
Upload 1.03
Ping 0.00
I'll start doing these every day and monitoring it..
Lynda~
