New Gateway kicked
- New Gateway kicked
New Gateway kicked
15-12-2014 3:56 PM
How to stop plusnet kicked you out of this gateway ptn-bng01. (Been connected for 2 weeks then get kicked out)
Re: New Gateway kicked
15-12-2014 4:00 PM
All the gateways should give similar performance so you shouldn't need to continually jump around them.
15-12-2014 4:03 PM
15-12-2014 4:09 PM
As an avid follower of the forums you will be aware that over recent months one has been markedly better off on the non-bng gateways.
Looking at the current gateway loading, one explanation for the difference might be that the old gateways are running near their maximum capacity, whilst all of the bng gateways are running below their recent maximums and way below their historical loadings of 70k+ users.
Does not the frequent disconnections from the bng gateways tell you something?
15-12-2014 4:15 PM
Quote from: Townman Does it really matter at those speeds?
The big different between 67 and 74 are does matter to me! Losing 7Meg is unacceptable for fibre with a sync rate of 80Meg. Old gateway give me horrible high ping of 16ms. While the new gateway give me 9ms.
15-12-2014 4:17 PM
15-12-2014 4:21 PM
jim:quote
15-12-2014 4:23 PM
You do take up an awful lot of people's time around here for what is frankly not an issue! You are in about the top 15% of the population for line speed. Be happy over that and chill.
15-12-2014 4:24 PM
Quote from: Oldjim for goodness sake why do you feel the need to keep running speed tests to get the last ounce out of your connection
Nothing else to do?
15-12-2014 4:25 PM
Just be thankful that on fibre the ISPs can't request DLM resets - otherwise he be demanding those every two days like he used to on ADSL!
15-12-2014 4:27 PM
15-12-2014 4:33 PM
15-12-2014 4:58 PM
15-12-2014 4:59 PM
As I've said many times before aaisp is for the more discerning fttc user (goldenfibre) while keeping the line rental with plusnet.
You can set your own LNS profile rates ( yes 110% ) and a host of other line settings at will.
http://wiki.aa.org.uk/Line_Options_and_Line_Settings
You can also run KBD and End to End Test from the comfort of the "clueless" control page.
http://wiki.aa.org.uk/Line_Diagnostics
http://wiki.aa.org.uk/Category:Control_Pages
goldenfibre can tweak to hearts content --
Dons tin foil hat for incoming from Townman & AndyH
Happy Xmas as well to everyone .
15-12-2014 6:00 PM
No incoming from this direction. Your comments are fair reasonable and sound. If one wants refinement in controls over the service, then one needs to find a provider offering that - and accept that there is a price tag on it.
A very happy Christmas to you too. Keep the tin foil for the Christmas turkey.
Kevin
