New Fibre broadband
- New Fibre broadband
New Fibre broadband
31-08-2017 10:34 AM
I see we have a new exchange box installed and the engineers working on it tell me that we will have fibre available very soon.
Will PLusnet automatically contact me when it is available or do I have to keep asking?
My existing router is "cable ready" so will I be able to use that?
Re: New Fibre broadband
31-08-2017 11:15 AM
Hi there!
You'd just need to check here occasionally to see if it's available: http://dslchecker.bt.com/
Once it is you can request an upgrade here: https://www.plus.net/upgrade_process.html
Re the router it depends on what type of cable service, does the documentation mention anything about FTTC or VDSL at all?
31-08-2017 12:30 PM
Ok will just keep checking.
Will look into router settings nearer the time. Its a Netgear D6300.
Cliff
31-08-2017 12:42 PM
31-08-2017 12:50 PM
You should be able to tell from the following link what stage your cabinet is at.
https://www.homeandwork.openreach.co.uk/when-can-i-get-fibre.aspx
04-10-2017 11:13 AM
04-10-2017 12:58 PM
It's all looking good, I've just popped a note on your account with the order completion date here, you can find that by clicking here.
05-10-2017 3:58 PM
