New Fibre Issues
- New Fibre Issues
Re: New Fibre Issues
04-06-2015 12:51 PM
04-06-2015 4:30 PM
I am using the Airport Extreme again at the moment.
05-06-2015 7:43 AM
What do we want to do now then? Can you send out a router to try, or do I need another engineer? Could there be yet another fault?
05-06-2015 8:33 AM
I also got an email this morning saying you not estimate my line to only be capable of 17mb. I don't think this is fair given all the issues I've had since the install. This now means should my speeds not be up to scratch you'll argue my line is only capable of 17mb which we know not to be true. Can this please be resolved?
05-06-2015 9:02 AM
Put your phone number into this link and tell us was it says for the FTTC Range A and FTTC Range B lines in the table.
Is your speed now lower than the lowest value in the FTTC Range B line?
3Mb FTTC
05-06-2015 9:55 AM
It's not at present no. I'm just concerned that now plus net have estimated my new line speed during a time where there is fault on the line it means that once this fault is resolved if anything goes wrong with speed in the future they'll argue they only estimated 17mb where the mine is capable of 68-80 (original estimate) and I've had the full 40 (capped by plusnet profile). This is sort of a side issue I don't want to be effected by in the future, at the moment I just want the constant disconnections fixed.
Thanks for your help
05-06-2015 11:31 AM
It is always good to keep copies of what this page says for your line, it is BT who at free will change what this page says just to match whatever your line happens to be doing, faults and all.
So keep old copies of this page just in case you need to show evidence of how your line has performed in the past.
3Mb FTTC
05-06-2015 12:19 PM
Do you have any news for what's going on?
05-06-2015 1:11 PM
05-06-2015 2:14 PM
05-06-2015 3:09 PM
05-06-2015 4:31 PM
I've seen two drops myself, do you have an accurate way to see how many drops there are ?
05-06-2015 4:46 PM
The modems sync is still perfect so if the drops continue I'd like to see how it performs over a direct connection again.
06-06-2015 10:59 AM
They're certainly much less frequent, maybe 2-3 times a day it seems.
07-06-2015 8:21 PM
Called up and need yet another engineer visit, seriously not impressed. £60 for a line install, what did that pay for? Clearly nobody checked the line was in working order when it was activated, and clearly the engineer that came out on Wednesday didn't resolve all the faults.
I feel like I'm entitled to some compensation at this point, not just for the service I haven't been able to use it properly, but also the the install costs and time that I've had to take off work. Surely part of the install should be checking the line works!?
