New Fibre Install Speeds
southerner
Hi, I just wondered if this looked about right for a new 40/20 fibre install?
~38Mb down, ~18Mb up.
Fixes: 62
Re: New Fibre Install Speeds
it looks wonderful and you would get a much better download speed if you go onto the 80/20 package but then again why pay more if you really don't need it
southerner
Great :-) Everything does seem nice and nippy now.
Would I be right in thinking there's no way to access the stats on the Openreach modem as they have locked it down? Was just interested in my synch stats.
You'd be right. Some bt modems can be hacked - but mine can't - or at least, not easily
Fixes: 62
The only way to check the downstream is via the BT Speedtest - Further diagnostics IP profile x 1.033 approx for the upstream there isn't
southerner
Ok, fair enough.
I have to say I wasn't impressed with the 'engineer install' They weren't BT, instead a sub-contractor by the look if it. All they wanted to do was plug in the Openreach modem and connect it to my PlusNet router and leave as quick as possible. It took some persuading to get my old master socket replaced with a new one as pictured in the leaflet that came with the fibre modem. I've wanted to get rid if that old thing for a while. They felt it wasn't necessary and that the old one could be left still using the filter. Also they didn't seem to know or couldn't be bothered answering anything about what I asked them. If that's all the 'engineer install' should consist of I would imagine it would be fine to just send the customer both the modem and the router and ask them to plug them in and connect them together with a LAN cable. Surely anyone can do that bearing in mind the PlusNet router sets itself up when it's connected to the Openreach modem.
timfibre
Hi Woodm.
I would like those speeds. I'm on 80/20 unlimited fibre extra and only get 32Mb download but I do get on average, 19Mb upload.
I've raised a ticket for them to check my line and speed so hopefully it'll improve  Undecided.
Fixes: 189
@timfibre
I'm sorry to hear that your having issues with your speeds. You appear to have started our troubleshooter but not gone through all the steps.
If you can complete that our faults team will get that looked into for you.
 Matthew Wheeler
timfibre
Hi Matthew.
Yeah i'll be looking in to it tonight, been without computer for a week or so. Will do the checks and get back to you.
Cheers.
timfibre
Hi Matthew.
Sorry but I can't find what steps i'm  to do next?? It just says the support team will get back to me. Can you shed any further light on the situation?Huh
Many Thanks.
Fixes: 189
You should be able to see them if you click here
https://faults.plus.net
 Matthew Wheeler
carlmagic
Quote from: woodm
Depends on which modem it is, If its the Huwaaiiiiii one then yes its just pressing the restart button down while it boots up connecting a PC to the LAN2 port and uploading different firmware to it, its that simple. You can then connect lan 2 to one of your routers LAN ports so you can monitor it like that. If its an ECI modem however your out of luck Sad
If you have the huwaiiiii one then google unlocking it and you will get loads of results Smiley
southerner
@carlmagic Thanks for the info. Unfortunately it looks like I got the ECI one going on a Google. Oh well.
southerner
So it seems I do infact need the Pro addon even with FTTC if I want to do anything constructive with my service of an evening. For the few hours I was without it it was like walking through treacle from about 6pm.
southerner
Also why does the PlusNet fibre router insist you type your admin password manually every time you want to go into the ACP? The ADSL one didn't, that remembered it through your browser.
