New Fibre Install Slow Speed
- Re: New Fibre Install Slow Speed
29-10-2015 9:26 AM
I had my line upgraded to fibre yesterday, and although i live quite far from the exchange, i was told by plusnet that i would get up to 76Mb. I opted for the 40Mb package, and was told that i would get a solid 40Mb.
My speed prior to upgrading ranged from between 4-6Mb, and having performed speed checks and using the Plusnet online portal, my current speed is still between 4-6Mb.
I'm obviously not happy, as i was told i'd be getting much higher speeds, and i am paying a premium price for effectively the same service.
Am i missing something here?! I received a text saying my order is now complete, but my speed is still the same as before
Drewan
29-10-2015 9:38 AM
29-10-2015 9:43 AM
Do plusnet technical support view these forums? I'm about to start work, and havent really got time to ring the support line!!
29-10-2015 10:50 AM
Edited for typo.
29-10-2015 12:47 PM
My new Open Reach Modem and connection was made 27 hours ago by BTOR engineer. I have just conducted a second BT speed test.
The maximum download speed so far is only 4.68 mbs. Upload = 1.83mbs.
I assume that this slowness is due to some delinquency at the PlusNet end.
Advice would be appreciated.
29-10-2015 12:50 PM
Check current line speed - link in my sig
29-10-2015 12:57 PM
29-10-2015 1:02 PM
Quote from: tj47 I, also, have slow speeds after update from ADSL to FTTC fibre broadband.
Hi TJ,
How far away from the exchange are you?
29-10-2015 1:05 PM
However we still need the Current Line Speed and BT speed test further diagnostics to check
If the current line speed is the problem (much less than the IP profile) use Chat to get it fixed
29-10-2015 1:43 PM
I've sorted that out, can you test again when you're able.
@tj47
Everything is set correctly on your account, if you don't see an improvement please ensure you're testing over a wired connection.
29-10-2015 2:13 PM
I have checked on the Portal and it states my current speed as 37Mb.
Will check my actual speed when i get home from work.
Thanks for looking into this for me
29-10-2015 3:01 PM
My BT modem is connected to the new master socket with a short wired link. The modem is connected to the plusnet router via short Ethernet cable. The router is connected to my PC via another short internet cable. No wireless/wifi involved.
All lights on both modem and router seem correct.
Performed hard reset of all hardware, including router and modem, before conducting speed test.
29-10-2015 3:03 PM
Quote from: tj47 Performed hard reset of all hardware, including router and modem, before conducting speed test.
Can you try that again with the router but leave it off for 30 seconds? We're not seeing the connection drop yet ( 22:54:17 (on going)_
29-10-2015 3:31 PM
Did a good long power-down of the router and modem. Test result 37.05mbs download speed. Which is amazing. In fact I am finding it difficult to believe, so ran it again (download = 36.84 mbs). Thank you for your help.
Out of interest. What happened between the previous hard reset (which I believe was over 30 secs) and test and this latest one?
29-10-2015 6:31 PM
Not happy!
