New Fibre Install - Great download, Poor upload speeds. - Please advise
- New Fibre Install - Great download, Poor upload sp...
Re: New Fibre Install - Great download, Poor upload speeds. - Please advise
08-01-2016 6:48 PM
Quote Looking at your posts on the PN forum, the main issue you seem to be facing is that the upstream bitloading is pretty bad - especially in the U2 band starting around tone 1980. This is resulting in a low sync speed.
It doesn't look like DLM has artificially lowered the upstream speed, as this low sync speed is achieved with the standard 6dB noise margin. "Banding" by DLM, or artificially setting a low sync speed, will result in an SNRM level notably higher than 6dB.
In fact, from the "--stats" output that is visible in the "pastebin" link, we can see that DLM hasn't intervened at all yet. The error rate (600 ES's in 10 hours) isn't enough to trigger DLM - at least not on a PN line.
You appear, at first glance, to be getting decent downstream speeds. Ordinarily, that would suggest that you are either suffering from noise and interference that is particular to the upstream frequencies, or you are transmitting at too low a power level - though there isn't necessarily anything you can do about either.
However, the bitloading graph shows your downstream loading has been done very differently from the norm too (see link later for a comparison example). Ordinarily, I'd expect a lot more of the D3 band to be used - instead, you seem to have a small "blip" of D3, and a lot of extra bits in D2 and D1.
Overall, it looks strange, suspicious even, and suggests your line isn't working as normal at all ... so perhaps your latest discovery of a tree rubbing the distribution cable is indeed the cause of the issues.
It might be useful to post a few more things from the HG612:
- The Hlog graph, which might give an idea of the state of the copper
- The QLN graph, which indicates how noisy your line is
- The SNR graph
- The data from the "--pbParams" command
All of these are things you can get from tabs on DSLstats; the latter two are within the "telnet data" tab.
It is probably easier to post images over on PN's forum, with a post here to say you've done it.
Other notes:
- Where you see reduced bit loading below tone 180 ... is normal. The FTTC cabinet is configured to reduce power on lower tones, so it doesn't interfere with ADSL signals from the exchange. The setting varies for each cabinet, so for some you see this notch at different tones.
- Your attenuation is 18.8dB, which is consistent with the speed estimates that BT provide. 80Mbps is certainly feasible downstream, just about, but it could easily drop somewhat as it gets affected by crosstalk - which will happen with increasing subscriber numbers.
Other posters are getting hung up on how long your line is, but they are forgetting that the gauge (thickness) of the copper is important, as well as the length.
An old line of mine had a 16.7dB attenuation, and was about 370m from the cabinet. That would suggest your line is behaving like a line that is only 410m long. However, it is entirely possible that your line uses thicker copper than normal - perhaps 0.6mm instead of 0.5mm.
That line started with an attainable speed of about 90Mbps, but that dropped as crosstalk took effect over 3 years, dropping eventually to 78Mbps.
The upstream attainable was well over 20Mbps throughout. Ordinarily, you ought to be in that region.
For comparison, here is what the graphs look like for that line:
http://postimg.org/image/vyrngmb11/
- I've had an even older line, that was 650m of copper. This was back in the days when only the 40/10 package existed, but it achieved a 10Mbps upstream easily, and reported an attainable of 16Mbps.
- The agent who told you "favouring download over upload" is talking nonsense. The distribution of upstream frequencies vs downstream ones is fixed nationwide, and everyone gets favoured the same.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
08-01-2016 7:52 PM
Cracking post there WWWombat, thank you very much. I'll get those stats you've requested up asap, I'd forgotten about my ThinkBroadband post!
09-01-2016 12:06 PM
This is the 2nd thread I've read where there's an unexplained loss of speed but particularly on the US where the bit loading was not what was expected.
09-01-2016 12:40 PM
I wish a tech would reply on here with their opinion, at the moment I feel like I'm lost within the Line Faults department, being passed from tech to tech with no solution in sight. This issue needs ONE Plusnet tech support person to manage it and see it to the end.
09-01-2016 12:44 PM
Quote from: WWWombat
- The SNR graph
Here we go!
I've also added another bitloading. Are the SNRperband of any use to you? I can upload those if required.
Quote xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 8883 Kbps, Downstream rate = 71284 Kbps
Bearer: 0, Upstream rate = 8879 Kbps, Downstream rate = 72375 Kbps
Discovery Phase (Initial) Band Plan
US: (7,32) (871,1205) (1972,2782)
DS: (33,859) (1216,1961) (2793,3959)
Medley Phase (Final) Band Plan
US: (7,32) (871,1205) (1972,2550)
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 8883 kbps 71284 kbps
Actual Aggregate Tx Power: 5.9 dBm 12.9 dBm
VDSL Band Status U0 U1 U2 U3 U4 D1 D2 D3
Line Attenuation(dB): 5.6 27.2 44.4 N/A N/A 13.8 35.1 61.1
Signal Attenuation(dB): 5.6 26.6 42.1 N/A N/A 15.4 34.8 61.3
SNR Margin(dB): 6.2 6.3 6.3 N/A N/A 5.9 5.9 5.9
TX Power(dBm): 0.4 -15.6 4.5 N/A N/A 9.8 7.7 6.1
09-01-2016 1:26 PM
09-01-2016 1:32 PM
09-01-2016 1:36 PM
09-01-2016 2:00 PM
I've attached two updated ones now, Thanks.
10-01-2016 9:45 AM
10-01-2016 12:03 PM
I've had a slow upstream since day one of the install, I was the second user to be jumped onto the new cab at that point, the other user is/was a neighbour 600 metres in the opposite direction, he gets the 20 upload and 70+ downsync!
12-01-2016 9:25 AM
Looks like interleaving has now been applied too.
Status: Showtime
Retrain Reason: 1
Max: Upstream rate = 8752 Kbps, Downstream rate = 74844 Kbps
Bearer: 0, Upstream rate = 8752 Kbps, Downstream rate = 77490 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Attainable Net Data Rate: 8752 kbps 74844 kbps
Actual Aggregate Tx Power: 6.0 dBm 13.1 dBm
Line Attenuation(dB): 5.5 27.0 44.2 N/A N/A 13.7 34.9 60.9
Signal Attenuation(dB): 5.5 26.4 41.9 N/A N/A 15.3 34.6 61.0
SNR Margin(dB): 5.8 6.1 6.2 N/A N/A 5.8 5.8 5.8
TX Power(dBm): 0.2 -16.2 4.6 N/A N/A 10.2 8.0 5.9
12-01-2016 3:42 PM
12-01-2016 6:22 PM
A bridged tap is basically some piece of wiring connected to your line that shouldn't be. Internal extension wiring could act as a bridged tap if the DSL signal goes along it, if the extension wiring isn't connected via a filter.
Is your phone extension wiring connected to the removable lower front plate of the master socket?
12-01-2016 6:28 PM
There is an extension that's connected via the Front Plate on the master socket, this runs through the attic then back down to supply the house phone. I've disconnected it before with no noticeable change to the connection stats.
The Openreach Modem is fed via the Filter on the MK3 Faceplate. It's also worth noting that the Engineer had his tester plugged into the test port of the NTE5A and could only get a max upsync of around 8000 - 9000 with the cab, does this rule out internal wiring?
