New Fibre Extra connection slow / not working
sudosaurus
My new unlimited Fibre Extra connection went live today, the blue light is steady ‘on’ on the Plusnet HubOne router however the connection is either super slow or not working at all. I am single occupancy and no one else is using the connection apart from me. I have given the router a reboot however still experiencing same issue. When I connect to the WiFi on my phone it loads the router page saying there is no internet connection on my phone yet the broadband status says it’s connected.
9 REPLIES 9
Fixes: 816
Re: New Fibre Extra connection slow / not working
Hi there.
Sorry to hear you're unable connect following your services going live.
It looks like your router wasn't properly scanned to your account before it was shipped, so the automatic setup process is struggling. If you can PM me the serial number and MAC number from the bottom, I can add your router to your account.
It may also be worth trying these steps to manually connect:
1. Open an internet browser and type http://192.168.1.254 into the address bar
2. Press the 'Enter' or 'Return' key
3. Click on 'Advanced Settings'
4. Enter the admin password, which is on the back of the router
5. Click on 'OK'
6. Click on 'Continue to Advanced Settings'
7. Click on 'Broadband'
8. Click on 'Disconnect' if necessary
9. Enter your broadband username, which is in the format of yourusername@plusdsl.net
10. Enter your broadband password, which is your account password
11. Click on 'Connect'
Let us know how it goes.
sudosaurus
Gandalf have sent you PM
Fixes: 816
Thanks for that, I've added it to your account now and it looks like we have lift off:
sudosaurus
Should I do a reboot as it’s not working still.
Fixes: 816
You shouldn't need to, are your devices connecting over WiFi or wired to your router?
sudosaurus
WiFi
Fixes: 816
Thanks for confirming. Are your devices connected to the wireless network?
sudosaurus
Hi Gandalf, I have changed my router over to an Asus VDSL router as the plusnet one was dropping out over WiFi.
The connection seems better with this one but the speed is rubbish, do I need to give you the serial number and MAC address of the router to update at your end to enable the faster speeds?
Fixes: 47
Hi @sudosaurus,
I've reviewed your account this afternoon and discovered an external fault which is most likely causing the issues that you're experiencing. I've raised a fault ticket via your account regarding this, which can be viewed here.
 Alex H
