New Fibre 76/20 order
Kieron
Hi, I'm due to have my fibre connected today according to the email I received when I made my order. I also made a check yesterday via the online chat to confirm all will be going ahead as scheduled. The gent did mention it could take upto midnight to complete.
Is everything still going to plan? Because I was expecting a text/email to confirm the activation will be taking place.
14 REPLIES 14
Fixes: 104
Re: New Fibre 76/20 order
Hi Kieron,
I've checked the account and the order is definitely set to complete today.
 Adam Walker
Kieron
That's great, I'm transferring from a TalkTalk ADSL connection that struggles to reach 10Mbps, so I'm looking forward to the extra speed. I'll update when it's live.
Fixes: 12
you may be surprised to find out that simply changing ISPs may not improve your speed.
if the speed is caused by line limitations then no ISP will improve that.
Kieron
Yes I certainly would not see any increase in speed if I moved to another ISP's ADSL based service. I should reiterate that with TalkTalk I'm on ADSL so I'm at the mercy of the distance from the exchange. It goes without saying that even if I was next door to the exchange, I would still only receive less than half the potential speed of FTTC. My estimated speed on FTTC is 71-80Mbps with a minimum guaranteed speed of 63Mbps, so I'm hopeful of a good boost. To be honest having suffered sub 5Mbps speeds at peak times with ADSL, I would even be chuffed with a minimum of 63Mbps.
mav:quote
Fixes: 10
Have you received your Plusnet router?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Kieron
Yes, I received it last Thursday, but it does mention in the quick guide to wait for the email/text confirming the connection is live before installing the router. I know it is perfectly fine to install it early and give it a reset once live, but it's not a problem to wait for the go ahead either. I'm still on my TalkTalk connection now, I was expecting the FTTC order to be complete by now to be honest.
mav:quote
scottymc
Post some router stats up when your connected bud
Best move I made upgrading to fibre.... enjoy!!
Kieron
Thanks, will post up some stats when all is working. I was not connected yesterday but I have lost connection to my TalkTalk  broadbad service this morning. I've connected the Hub One and the b light is flashing red with a orange status light so it's not completed yet. I'll restart the Hub One in a few hours to see if I can get online.
Kieron
Got an update from live chat and the order was completed but the supplier did not notify plusnet. The order has now been logged as complete and should be functional within the next 30 minutes.
Kieron
Contacted support a few times to eventually get through to one advisor who checked my line and said there seems to be a fault on itt. I have tried to use the online broadband troubleshooter to report a fault but I get this error when trying to submit it "We're sorry, but you can't use the Broadband Troubleshooter to report a fault on your service. Please contact our Support Team for help."
I've ordered broadband only as I've had no problems with my phone line supplier.
Fixes: 167
Taking a look now, I think I've fixed the reason for the fault checker not working though so you should be able to run through that.
 Chris Parr
 Plusnet Staff
Fixes: 167
Unfortunately it is likely to need an engineer to fix this. If you can report the fault at the faults checker and let us know your availability for an engineer in the comments, we'll get this looked at asap.
 Chris Parr
 Plusnet Staff
Kieron
Ok thanks for looking in to this, I've completed the troubleshooter and it's been put to the team for review. Also added availability for an engineer to the comments.
Kieron
Up and running now after an engineer visit this morning, was at work but thankful to come back home with the Hub One showing a sold blue light. My first speedtest using a ethernet cable:
Router Stats:
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ53923906
3. Firmware version: Software version 4.7.5.1.83.8.217 Last updated Unknown
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 03:31:45
6. Data rate: 20000 / 72692
7. Maximum data rate: 21780 / 72451
8. Noise margin: 6.9 / 6.5
9. Line attenuation: 16.9 / 15.1
10. Signal attenuation: 16.2 / 15.1
11. Data sent/received: 23.8 MB / 616.0 MB
12. Broadband username: @plusdsl.net
13. 2.4 GHz Wireless network/SSID: PLUSNET-
14. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
17. 5 GHz Wireless network/SSID: PLUSNET-
18. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: Automatic (Smart Wireless)
21. Firewall: Default
22. MAC Address:
23. Modulation: G.993.2 Annex B
24. Software variant: AA
25. Boot loader: 1.0.0
