New Fiber Install
Cheltgar37
New Fiber Install
Hi
i have just been switched over from BT.
I plugged the router in to the master socket, and allowed the system to setup. Connected via wifi, but just got orange lights.
Read posts on the forum, and it suggested login in as Admin and resetting password. Did this in the web, then logged in to admin and reset the password. Then rebooting computer and router. Twice.
still just get static orange lights
help please
Gareth
Fixes: 247
Re: New Fiber Install
You might just need to be activated at PN's end, hopefully one of the support guys will be able to do this for you shortly.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
MattyC
Champion
Fixes: 46
That'll be me.
Are you ok to have another go at it?
