New Fiber Install, Speeds Dropped After Midnight
- Re: New Fiber Install, Speeds Dropped After Midnig...
12-02-2016 1:05 AM
And then after midnight, download dropped to around 18-20mbits.
No wireless, all wired.
I turned the wireless off.
Tried connecting to a different ip profile, no difference.
Information for Helpdesk agents
When contacting the Plusnet Broadband helpdesk, the agent might ask you for details about your Plusnet Hub. This page contains all of the information they are likely to request.
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ53926085
3. Firmware version: Software version 4.7.5.1.83.8.217.1.1 Last updated 11/02/16
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 00:38:04
6. Data rate: 20000 / 79995
7. Maximum data rate: 28044 / 82211
8. Noise margin: 9.7 / 7.4
9. Line attenuation: 9.9 / 11.1
10. Signal attenuation: 9.9 / 11.1
11. Data sent/received: 265.9 MB / 311.5 MB
12. Broadband username: [Removed]
13. 2.4 GHz Wireless network/SSID: PLUSNET-QRX8
14. 2.4 GHz Wireless connections: Disabled
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
17. 5 GHz Wireless network/SSID: PLUSNET-QRX8
18. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: Automatic (Smart Wireless)
21. Firewall: Default
22. MAC Address: 8c:10:d4:1b:59:ce
23. Modulation: G.993.2 Annex B
24. Software variant: AA
25. Boot loader: 1.0.0
[Moderator's note by Mike (Mav): email address removed from a public forum.
Re: New Fiber Install, Speeds Dropped After Midnight
12-02-2016 6:05 AM
Speed might settle down in the morning try another speed test when you get up
12-02-2016 6:44 AM
I could try resetting it but I don't think it would make a difference.
Or other people, would be having the same issue.
With this router.
12-02-2016 7:00 AM
Go there see what your PlusNet profile/line speed is..
You will need to login
12-02-2016 8:44 AM
Quote Estimated line speed:
80Mb (This may vary between 74Mb and 80Mb) - Checked on 2016-01-27 17:03:13
Current line speed:
21 Mb
First thing I did but thanks anyway.
dick:quote
12-02-2016 9:00 AM
12-02-2016 9:03 AM
No difference, direct to the router.
Or through 600mbit powerline adapters, using two cat6e cables.
All was good until after midnight.
What I usually get.
Even worse now.
12-02-2016 10:26 AM
12-02-2016 10:51 AM
Quote from: tfn016 What I usually get.
First Result
Second Result
Third Test
Fourth Test
Might have been a faulty cable, going from the socket to the router.
As the old one dropped me to 4-6mbit down.
No idea, why it would fail so quickly.
Current line speed:
78 Mb
So I might try replacing the cat6e cable downstairs, clips are a bit loose.
That might not be helping.
12-02-2016 11:05 AM
12-02-2016 11:51 AM
The cable for the modem was screwed!
Number one, replaced it.
Secondly my TCP settings were screwed, so I fixed them.
And things seem better but I understand, I'm still within my first 10 days.
12-02-2016 1:09 PM
It should be full speed from day 1.
