New FTTC speed same as old ADSL
- Re: New FTTC speed same as old ADSL
22-12-2014 1:16 PM
Hello,
I've just had FTTC installed but when I do a speed check it is the same speed as my old connection (5Mb/s)
Is this a profile issue as I should be getting 40Mb down?
Message 1 of 4
(606 Views)
3 REPLIES 3
22-12-2014 1:59 PM
Probably - hopefully someone on DCT will be along shortly to fix it for you. Alternatively if you can put up with the on hold wait, the phone support should be able to do the same.
Message 2 of 4
(397 Views)
22-12-2014 3:02 PM
Hi jamiethompson,
I've corrected the speed profile on your account.
You might just need to <a href="https://www.plus.net/home-broadband/router-reconnect/">reboot</a> for that to take effect.
Message 3 of 4
(397 Views)
22-12-2014 3:11 PM
That's much better (42Mb :D)
Thank you
Thank you
Message 4 of 4
(397 Views)
